Go to Post I believe the only cure... is more cowbell? :D - The Megan 2207 [more]
Unread 22-01-2012, 21:34
collegebound collegebound is offline
FRC #1660 (Harlem Knights)
Rookie Year: 2011
collegebound is an unknown quantity at this point
Question Eclipse Vs. NetBeans
What is the difference between Eclipse and Netbeans?
Which one do you guys think is more efficient?
Unread 22-01-2012, 22:30
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
Rookie Year: 2012
shuhao is an unknown quantity at this point
Re: Eclipse Vs. NetBeans
Both of them are bloated as hell.
Netbeans is a pile of ----. I have not met a single person (online or IRL) who has anything good to say about it. No configurability, it eats ram and CPU like an IDE and acts like a text editor, crappy looking GUI
Eclipse is the lesser of 2 evil. Still very bloated, at least you get options, and the editor actually autocompletes stuff for you.
Ideally I would pick neither, but under the circumstances my vote is with Eclipse
Unread 22-01-2012, 23:07
Rookie Year: 2011
ok thanks
Unread 22-01-2012, 23:24
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
While it sounds like shuhao may have experience with both IDEs outside of FRC, I think you also need to consider how well they work with the FRC plugins. It seems that this year, netbeans is updated faster, and also has many more users. Given that the FRC build season is so short that the ability to get support would probably be towards the top of features I was looking for.
Unread 22-01-2012, 23:48
Rookie Year: 2012
You're absolutely correct. However it would seem the only things that really matter is the sunspotsdk files, and a couple of ant build files.. which can easily be pulled and pushed into the eclipse installation in case there's an update.
At the end of the day, it's just an ant build file
Unread 23-01-2012, 00:04
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
We've had no issue with autocomplete in netbeans. Could you clarify when you are having an issue with it performing properly?
Unread 23-01-2012, 01:52
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
I use Netbeans as my preferred IDE. When I want to throw together a quick java GUI, you can't beat it. And by the way, there are plug ins for it.
As far as IDEs go, I haven't had too much experience with many others (I usually only program in java, and most IDEs are for other languages. I feel a bit like a tourist). I've used MPLAB, Matlab, JCreator, XCode, Codewarrior and Bloodshed before, and I've played around with Labview, Codewrite and Eclipse.
I suppose I could say I also have used notepad, gedit and VI from time to time, but you could hardly call those IDEs.
My advice is to find something you like for the application/language you're writing, become proficient with it and stick to it. It helps when either it is the language's standard, or has a large user base along with plug-ins.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 23-01-2012, 02:08
patrickviolette patrickviolette is offline
FRC #1318
patrickviolette is an unknown quantity at this point
It's kind of a holy war in IDEs. The truth is, either will work.
NetBeans is the best supported. To get the SunSpotFRCSKD in Eclipse, you have to first unpack it as a NetBeans Module, and then copy the JAR files to your Eclipse project.
At our school, the AP Computer Science class uses Eclipse, and our mentors are most comfortable in Eclipse, so that's what we use. It deploys fine.
If you are completely new, NetBeans seems like the way to go because of the support.
Unread 23-01-2012, 07:58
Rookie Year: 2012
Sorry. I meant auto save actions. Also things like auto import .. etc.
My preferred IDE is no IDE. The main editor I use is geany, and secondary is vim, where geany I use for larger projects, and vim I use for 1-2 file projects. I would say I'm rather proficient in geany and vim.. but then both are just text editors.. not much to learn (vim people please don't hate me for saying that..)
I use eclipse when I have to write Java (because Java is an eclipse proprietary language, amirite? ) due to the fact of the massive amount of options in eclipse, so I can customize it to my needs relatively well (take the time to go through every single options in eclipse.. then do the same for netbeans.. then you realize why eclipse is much much superior), but the IDE is still slow and bloated ("Let me get some coffee while I wait for Eclipse to redraw it's main GUI")
That being said.. It's just my opinions, and I have very very strong opinions over these kinda things.. (maybe I have OCD? not sure..)
Unread 23-01-2012, 08:12
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Use whatever IDE integrates best with the language and tools you are using, and you are most comfortable with.
I've worked with graphical languages which are their own IDE's (LabVIEW/Simulink), and IDE's like MATLAB, EasyC/RobotC (VEX), MPLAB (IFI/VEX), Eclipse (Android dev), Notepad++, and others. I've also worked with just gedit to write a lot of fairly simple Perl scripts.
I never really felt that any one of the above editors was limiting me except for EasyC (that editor as a text editor is awful). In most cases, I used the editor I was given or the editor that worked with the build chain. In many embedded cases, the build chain is designed to work with a single editor, or even integrated directly into the editor, so you use what you can.
Kettering Motorsports
Unread 23-01-2012, 08:27
Rookie Year: 2012
Is no one a makefile fan...
Unread 23-01-2012, 22:23
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
NetBeans autocompletes too.
One issue I have with NetBeans is that it has a "main project selection" feature, whereby you must select the project you want to deploy to your robot as the "main project." However, when you open a saved project, it does not automatically consider that newly opened project the "main" project, which can cause you to accidentally load the wrong code. Eclipse does away with this "main" project concept.
Unread 26-01-2012, 21:35
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Rookie Year: 2012
Chiller is on a distinguished road
Netbeans is also VERY childish looking, its like what a beginner wold use to program in java. Eclipse is the better one.
