Go to Post I wish I had two extra hands, so I could give those gearboxes four thumbs up! - Billfred [more]
Unread 22-01-2012, 23:25
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Exclamation Programming Vision Tracking
Hello. I am trying to make a basic program that enables our robot to simply turn to face the vision target. I have already used the vision assistant to make a reliable .vi and I need help with the rest of the program inside labview.
Link to file:
www dot mediafire dot com/?84xtjrnrw421cr2
(replace "dot" with period)
So basically I don't know:
A. How to ftp the reference image onto the crio and have the program know where it is.
B. Whether the rest of the program will work
C. Am I missing anything?
Thanks!
Unread 22-01-2012, 23:29
FRC #3476
Talking Re: Programming Vision Tracking
I just realized that you will need the vision .vi too.
here: www dot mediafire dot com/?k8pndljn4x76a8o
I believe that if you extract the "custom vi" folder to your documents it should work.
Unread 23-01-2012, 11:08
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Your new vi's just need to
  1. Get copied into the appropriate Documents->LabVIEW Data project folder
  2. Open your LabVIEW project
  3. Then drag the new vi's from the project folder onto the Project Explorer window and onto the Team Code sub-folder
  4. Add the appropriate vi calls to your regular code
It all gets compiled into your regular project and downloaded as an integral part of that.
Unread 23-01-2012, 20:39
FRC #3476
Ok, what about ftp-ing the reference image?
Unread 23-01-2012, 22:34
I'm a little unsure of what reference image needs to be ftp-ed, but you can use any ftp program, or even the MS File Explorer. You type ftp://10.te.am.02 into the file path prompt and you should see the cRIO file system via ftp. I don't have one with me, but select a directory to put the image and drag it in. You may then need to update the path to point to that location. For paths on the cRIO built on Windows, I think that c:\ is equivalent to the / root.
Greg McKaskle
