Go to Post Ya know something I heard, UFH always look beter in PINK! :) - Kyle Love [more]
Unread 23-01-2012, 19:15
jhellr13 jhellr13 is offline
FRC #4272
Rookie Year: 2010
jhellr13 is an unknown quantity at this point
Ultrasonic sensor help needed
Hey guys
Been playing around with the ultrasonic sensor for a few days now. We have it set up plugged into the analog port 1. I initially used the labview example to test it, but the number given never changed. Today, I worked with new code that I found online. Attached is this code. It correctly gets the voltage like it is programmed and displays it to the dashboard, but in lays a tougher problem. Once again the number never changes. The voltage shown sticks at something like 4.56 for the sensor and never changes if I move it around.
Any ideas?
Name:	Ultrasonic code picture.jpg
Unread 23-01-2012, 20:27
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Ultrasonic sensor help needed
Your code looks fine. How did you wire the sensor? Do you have a DMM that you can use to measure the sensor independently?
Unread 23-01-2012, 20:38
FRC #4272
Rookie Year: 2010
We soldered pwm wires to the sensor according to the diagram given on the sensor website for analog, so it's correct. The soldered wires are a part of a pwm cable that ends with a male connector. This male connector is then connected to a female to female pwm cable that is put into the analog breakout on the cRIO.
We do probably have a DMM lying around. How would i go about testing the sensor?
Unread 23-01-2012, 21:21
DonRotolo's Avatar
Back to humble
FRC #0832
Verify that there is +5 volts on the +5 pin, with the black DMM lead on the GND pin. If not, check both. Verify correct polarity at the same time.
If yes, then put something about feet from the sensor - the ceiling makes a nice target if you're working on a table. The voltage at tha AN pin, again with the black DMM lead on the GND pin, should be about 0.6 volts - more precisely, it should be 0.01 volt per inch. 60" = 0.6 V
If all that is fine, the sensor is working properly.
Unread 23-01-2012, 21:32
FRC #4272
Rookie Year: 2010
Thanks for the help. I'll try this tomorrow.
What should I do if the sensor still remains at the constant 4.56 volts or so?
Unread 23-01-2012, 22:01
DonRotolo's Avatar
Back to humble
FRC #0832
Get another one, 'cause that one's bit the dust.
All assumes that you know what you're saying when you wrote "so its correct". Maybe have someone look real carefully for solder bridges and other issues?
Unread 23-01-2012, 22:03
FRC #4272
Rookie Year: 2010
I sure hope it's fine! Do you think it may be a "dead" one because of the constant voltage it shows?
Unread 23-01-2012, 22:33
DonRotolo's Avatar
Back to humble
FRC #0832
My suspicion is that you're reading the supply voltage. Particularly because the sensor has a maximum range of 255 inches (2.55 volts). But it's fed with about 5 volts...
Little solder globs can do that sort of thing. As can little 'hairs' of copper wire. and so on.
Unread 23-01-2012, 22:37
FRC #4272
Rookie Year: 2010
Thanks. I'll check it out tomorrow
