Go to Post If you guys ever need anything, just let us know. Just remember you have the FIRST family behind you.<3 - hayleybayley217 [more]
Unread 23-01-2012, 20:19
dcarswell's Avatar
dcarswell dcarswell is offline
FRC Mentor/Old Dominion University
AKA: DeAndre Carswell
FRC #3359 (Royal Robotics)
dcarswell is an unknown quantity at this point
COMPRESSOR PROGRAMMING HELP
Hello,
Our team is trying to program the robot so that when we turn it on, the compressor fills up the tanks until it reaches the max psi it is supposed to go, and then with a press of a button the solenoid opens and the piston goes forward. And everytime the tank goes under pressure, it refills.
This is the code I have so far. .Could you give me some extra insight unto what I am doing wrong..
Thank you, very much
Uploaded with ImageShack.us
Unread 23-01-2012, 22:44
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: COMPRESSOR PROGRAMMING HELP
The code's in the wrong vi.
Some of it belongs in Begin.vi and one piece belongs in Periodic Tasks.vi
Unread 23-01-2012, 23:34
dcarswell's Avatar
Thank you very much .
Unread 25-01-2012, 18:07
bbsoccergamer's Avatar
bbsoccergamer bbsoccergamer is offline
AKA: Lee Knepper
FRC #0703 (Phoenix)
Team Role: Coach
bbsoccergamer is an unknown quantity at this point
Send a message via AIM to bbsoccergamer
You Sir deserve a bunch of cookies, this worked for us as well!
Unread 25-01-2012, 18:36
Just Itinerant
I like cookies...
Unread 28-01-2012, 04:47
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Post Re: COMPRESSOR PROGRAMMING HELP
Hey,
We are also using pneumatics this year. But we havent programmed any pneumatics. We couldnt understand what control loop is? Can anyone please help us?
Unread 28-01-2012, 09:13
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
Team Role: Teacher
Rookie Year: 2011
NeatNit is an unknown quantity at this point
It's just something that you're supposed to put inside Periodic Tasks and forget about it. It takes care of stopping the compressor when the pressure sensor turns on.
Unread 29-01-2012, 12:56
FRC #2905
Exclamation Re: COMPRESSOR PROGRAMMING HELP
We got our compressor working by this code however our solenoids dont work. Any suggestions or recommendations??
Unread 29-01-2012, 17:10
NeatNit's Avatar
Alumni Programmer
Team Role: Teacher
Rookie Year: 2011
It is generally bad practice to use Open inside teleop. Instead, use Open in Begin, then insert to a RefNum Registry Set and give it a name. In Teleop, use Refnum Registry Get. Then give it a command. See how the default code has the joystick and RobotDrive. All you have to do is use the same palette as what you're working with.
Try the Compressor With Cylinder example, see if it works. Don't forget to change the RT CompactRIO Target IP address by changing its properties.
