Go to Post FIRST needs a disclaimer that parts of the field can become flying projectiles under hurricane force winds. - Barry Bonzack [more]
Unread 24-01-2012, 02:46
Dan Radion Dan Radion is offline
Dan
FRC #2903 (The NeoBots)
Team Role: Leadership
Dan Radion is an unknown quantity at this point
P60 Gearbox Compatibility
Hi.
Has anyone tried attaching an AndyMark or Fisherprice motor to a RS-5nn P60 gearbox? The motors seem to all have very similar shaft specs.
AndyMark Motor
Fisherprice Motor
P60 gearbox
We're planning on having three RS-550 BaneBot motors with P60 gearboxes for our three conveyor belts.
We were thinking about using AM planetary gears for the AndyMark and Fisherprice motors, but they are out of stock and we don't know when they will restock.
Thanks.
Unread 24-01-2012, 02:47
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: P60 Gearbox Compatibility
These are all standard 500 size motors, (.125" shaft, M3 bolts on 25mm spacing) and will be completely interchangeable.
There will be slight variances in shaft diameter/length (diameter barely changes), and more so on can diameter/length; but they are still all completely interchangeable.
Unread 24-01-2012, 02:52
Dan
That was a quick reply!
Thanks, Adam.
Unread 24-01-2012, 11:04
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Originally Posted by Dan Radion View Post
Hi.
AndyMark Motor
Fisherprice Motor
P60 gearbox
Thanks.
The BB motors do not have Knurled shafts. The AM and FP motors do.
The P60 gearbox pinion is not set up for the shaft being knurled so you may need to sand the shaft (Just a bit, not too much).
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 29-01-2012, 17:37
mehrkam's Avatar
mehrkam mehrkam is offline
Paul Mehrkam
FRC #0836 (Robobees 836)
Rookie Year: 2007
mehrkam is on a distinguished road
We have mounted the Fisher Price motors to the BaneBot P60 transmissions in the past. This year we are using several 500 series motors which will include the Banebot RS550, AM, and FP.
We have 3 conveyor belt zones to control and 2 ball intake rollers.
Good luck.
