Go to Post I am used to politicians getting up and being blowhards. - Steve W [more]
Unread 24-01-2012, 08:06
hsekhon27 hsekhon27 is offline
FRC #0280 (TNT)
Rookie Year: 2011
hsekhon27 is an unknown quantity at this point
Setting RPMs on motors
To get an accurate trajectory on the ball, I wanna preset the RPMs on the shooting motor. I know you can just put in integer values like 1 for the motor speed, but what do these numbers mean? 1 meaning 1000 RPM?
Unread 24-01-2012, 08:19
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
Re: Setting RPMs on motors
The output 0-1 is just a power value, 0 being stopped 1 being full power. To do RPM control you need some type of feedback, like an encoder.
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 24-01-2012, 08:21
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The numbers -1 to 1 only refer to the battery voltage as it is at the moment.
It won't give you a specific RPM and will vary as you syphon power off to other motors (like your drivetrain), and as your battery gradually depletes itself during a match.
To get a consistent RPM you will need a feedback sensor and what's called a PID software loop to maintain a set RPM.
For feedback you can use an encoder (some come in the Kit of Parts), or a light sensor that counts the passing of a marker on your spinning shooter wheel, or various other types of measuring sensors/devices.
Unread 24-01-2012, 12:22
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
If you are using CAN with Jaguars, then you can easily set speeds using their built-in control feedback loop system and plugging your encoder into your Jaguar. For Java, see the CANJaguar javadocs, and note the "control mode" variable, which you can set to kSpeed, setPID(), and set() method. You will have to tell it how many encoder codes your encoder will report per revolution as well.
If you want to see an example of making your own feedback loops for Victors, you can check out a (Java) class we wrote last year to do this here.
Unread 24-01-2012, 14:15
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Have you successfully done this?
Unread 24-01-2012, 16:04
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Here is a picture of periodic task that we have run on our test platform. It seems to perform quite well for maintaining desired RPM. YMMV.
The simple explanation is that we are using this like the "I" function in PID. This runs 100 times per second.
The 250 multiplier/divisor is found by reading your maximum rate count without feedback at full speed.
Name:	Rate control.JPG
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 24-01-2012, 16:24
Ether's Avatar
Rookie Year: 1969
Plus feedforward.
Unread 24-01-2012, 21:46
FRC #0280 (TNT)
Rookie Year: 2011
Okay I have never programmed an encoder before and I'm confused by the begin vi. Can someone please post a sample code for an encoder to set the desired RPMs? Thanks
Unread 24-01-2012, 22:33
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
Team Role: Coach
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
We have!
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 24-01-2012, 23:21
Ether's Avatar
Rookie Year: 1969
Originally Posted by bhsrobotics1671 View Post
We have!
With a drivetrain too? Or just a free-spinning wheel?
Unread 24-01-2012, 23:32
pfreivald's Avatar
pfreivald pfreivald is online now
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Our plan is to use the kit encoders direct-mounted to our flywheel shafts. Does anyone know if the manufacturer claim of up to 10,000 rpm is accurate? We'd rather not add the weight, complexity, and inefficiency of having to gear down an idler for the encoder to take rates.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 24-01-2012, 23:50
FRC #0280 (TNT)
Rookie Year: 2011
Just the wheel
Unread 25-01-2012, 00:18
Alex Carrillo
Define "success." We did it on our drivetrain last year, with each wheel being controlled separately, and tuned the values using BDC-COMM. Were we able to control the speed of the wheels comfortably? Yes. But we faced typical Jaguar reliability issues that led us to replace them with Victors + homebrewed speed control code.
Unread 25-01-2012, 08:33
Ether's Avatar
Rookie Year: 1969
Define "success."
In this context, I guess I meant:
- did you measure the actual steady-state output speed and confirm that it was indeed equal to the speed you were commanding?
- was it stable?
- was the dynamic response "good"? (I know, define "good". How about a rough estimate of step response compared to voltage mode or %Vbus mode)
- for a given speed command, did the controller hold the same output speed under different loads?
The reason I ask is that if you were successful, the folks at this thread would like to hear about it:
http://www.chiefdelphi.com/forums/sh...d.php?t=100135
  #15   Spotlight this post!
Unread 25-01-2012, 10:08
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
You can use a PID Controller and use RPM as the unit.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
