Go to Post As usual this was the programmers fault. - Swampdude [more]
Unread 24-01-2012, 11:35
malachias malachias is offline
FRC #1311
malachias is on a distinguished road
IMAQ images and Memory Management
I have not seen any code that disposed of Image instances (i.e., GetImaqImage()). I do, however, see code delete the source image and then use the underlying Image instance, which leads me to believe that ImageBase is not the owner of the Image instance. Am I to assume that they are managed by the IMAQ vision library. I can see generating a lot of these Images during a competition and although they tend to be small I can easily run out of memory if the resource is not freed.
Thanks
