Go to Post [Bring] programmers [to Championships], they may be small, quite and easy to miss while leaving for Atlanta but its hard to do anything robotic without them, I've tried. - Simon Strauss [more]
Unread 24-01-2012, 18:35
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
2011 Labview Code on new cRIO
Should our 2011 FRC Robot Code work without modification on the new cRIO and associated image? It seems to me the answer should be yes.
If no, are there simple changes that can be made to make it completely compatible?
I'm trying to help my team debug a software issue from afar and I just want to get the facts straight.
Thanks.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 24-01-2012, 20:41
Re: 2011 Labview Code on new cRIO
If the code is recompiled, yes, it should work. There were a few changes to WPILib, such as the camera and compressor needing to have the control VI dropped in Vision or Periodic. Otherwise, I would expect the code to work.
Greg McKaskle
Unread 24-01-2012, 20:56
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Did they change the cRIO modules to the new order?
Another thing that doesn't get updated correctly is the digital module number (if it was explicitly set).
Unread 26-01-2012, 17:17
jcbc's Avatar
jcbc jcbc is offline
AKA: Julie
Rookie Year: 2011
jcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the rough
Our code for last year worked without problems with the new LabVIEW and cRIO image. We moved the cRIO modules to where they are supposed to be. Since we used the default locations for the modules last year, we didn't have to change anything in our Begin VI to correct module numbers as they updated themselves automatically.
