Go to Post ..."A bad day at college is always better then a good day at work" - KyleGilbert45 [more]
Unread 24-01-2012, 22:02
chall3613 chall3613 is offline
AKA: Candace
FRC #3613 (Team Wolf Pack)
Rookie Year: 2011
chall3613 is an unknown quantity at this point
Question labview Drive Programming, 2 Joysticks, 4 Motors
I know there is already a thread about this, but it was from last year, 2011 Labview. So question. How do you program 4 different wheels being controlled SEPARATELY? Is that possible? Because then 2 wheels will only go one direction, unlike the other two that will go forward and back because the joystick is.
Last year we were a rookie team and we only had 2 motors, tank drive. Also, we used the triggers on the joysticks to move a window motor forward and backwards. (Right-forward, Left-back).
Right now, I've got the 4 motors in the begin.vi, all going to a open 4 motor and the 2 joysticks in USB 1 and 2.
Please, and Thank you!
Unread 24-01-2012, 22:18
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: labview Drive Programming, 2 Joysticks, 4 Motors
If you wire your Open 4 Motor to a Drive RefNum Set and give it a name, you'll be able to use a Drive RefNum Get to open it. You'll then wire the two axis from your joysticks to the tank drive module. Moving from two to four motors takes a bit of logical thinking in terms of what goes where, and what should do what. It's best to do the coding in front of your bot.
