Go to Post ...SEARCH BEFORE YOU POST, and when you do post think twice before pressing the 'post' button. - Brandon Martus [more]
Unread 25-01-2012, 13:43
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
tilky is an unknown quantity at this point
digital input
We have an external DI switchboard that we want to know how to code. When we open driverstation, it comes up under the i/o with DIs, so we know the computer sees it, but we don't know how we would be able to use them in the code. We tried opening a DIO in begin, but that is only for i/o's on the digital sidecar.
Unread 25-01-2012, 14:10
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: digital input
By default the digital IO you get from the Cypress board connected to the Driver Station is in "Compatibility Mode".
The vi's to get the data inside your code can be found in the programming palette:
WPI Library -> Driver Station -> Compatibility IO
The vi's you'll use most are:
  • Get Digital In
  • Get Analog In
There is an extended set also available called "Enhanced Mode"
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Re: digital input
Under the Driver's Station Palette, there is an Get Digital IO.
WPI Robotics Library/Driver's Station/Compatibility IO/Get Digital Input
Unread 25-01-2012, 14:27
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
Re: digital input
Thanks
Unread 26-01-2012, 14:22
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
Re: digital input
ok we ran into another problem. We know how to read it, but then how would we read only one of them, and then see if it is true?
Unread 26-01-2012, 14:36
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
Re: digital input
nevermind we got it.
