Go to Post Remember, FIRST is merely a means to an end - the end result being that we completely change the world for the better. - RogerR [more]
Unread 25-01-2012, 14:54
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
General Purpose Connectors
[I realize there is another thread about connectors going right now, but that is mostly about power connectors.. ]
For the last two years our team has been doing a modular electronics box that is easily removable, which has been extremely useful for us. We've been using 2 or 3 AMP connectors (similar to the ones shown here: http://www.newark.com/catalog_129/index.html?page=931) with a dozen or so sets of wires each.
These have worked out really great when they work, and makes it really easy to remove the electronics and insert new things when necessary. However, they have a number of drawbacks:
a) Requires a special tool to insert/remove/crimp them
b) If not done correctly, they can be unreliable
c) Running a ton of wires to a single connector, makes it really annoying to add new wires to it as it fills up
What kinds of solutions have your teams used in the past (or currently) for this sort of thing. We anticipate lots of sensors and motors, so something that is easily scalable would be ideal.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 25-01-2012, 15:22
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
Re: General Purpose Connectors
Pretty much no matter what connectors you choose you will run into those 3 same problems. So I'd continue to use what you have in the past assuming you are happy with their performance in the past, which it sounds like you are and you've obtained the proper tools to crimp and remove them.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 26-01-2012, 07:58
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Dustin,
While that AMP connector line is pretty nice, you can't find contacts in the connectors you show that are rated for the currents you encounter on motors on an FRC robot. I believe the series 3 contacts are the only ones that come close. While using your design is not illegal, I would suggest that the addition of another set of contacts, adds another possible fault and higher series resistance to your motor connections in addition to the added complexity of construction and cost.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 26-01-2012, 12:54
virtuald's Avatar
RobotPy Guy
Al,
Thanks for the input. The complexity of construction is really the problem that concerns me, it seems like we always have one or two things that either get mixed up or aren't connected reliably and cause problems.
For drive motors and motors that actually do something, we were using the larger contacts in the series 4 connectors, which are rated at 35A -- so it's better, but not quite able to handle the max current as you pointed out.
Dustin
Unread 26-01-2012, 13:34
Unsung FIRST Hero
Rookie Year: 1996
Dustin,
The problem with some of these connectors is that at higher currents, the contact gets hot. As that happens (depending on the body material) the contacts can melt and touch internally. With a visual inspection they may not look bad, but a closer look with a brilliant light and a magnifier will usually point out a failure. For the series 1 & 2 connectors, I try to keep them in the under 5 amp range when I do use them. I like AMP and frequently use them in audio apps where we are terminating 30 to 60 pairs (plus shields) in a single connector. For those applications, we use machined, gold plated pins. Over the years I have become very adept at pin removal and crimping. I have the parts for a project sitting on my bench right now. 30 mics terminated in a single connector body for a studio box.
Al
WB9UVJ
www.wildstang.org
