Go to Post Brandon is my hero :) - Cory [more]
Unread 25-01-2012, 15:51
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Rookie Year: 1999
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Banebots 775 Pinion Specs
I've looked on Banebots web site, searched here, but I am unable to find the Pressure Angle and the Diametral Pitch
for the 15T Pinion(P60P-GM4050) for the RS-775-18V motor.
Does anyone happen to have that data?
Thanks,
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 14-02-2012, 15:42
Phalanx's Avatar
Rookie Year: 1999
Re: Banebots 775 Pinion Specs
Well to respond to my own post and to share with anyone else who might was this information. After emailing Banebots I received the following response:
"The gear is module 0.6 (not DP) with a 20 degree pressure angle."
Now if I understood things correctly. To convert the module (Mod) to DP
It's divide 25.4 by the module: 25.4 / 0.6 = 42.33DP
Alternatively, if I get time, I might try:
Divide number of teeth + 2 by the outside diameter
DP = (N+2)/OD
and compare my results.
Unread 14-02-2012, 16:08
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
DP = (N+2)/OD
You are correct that the DP of a 0.6mod gear is 42.333, but Diametral Pitch is used for inch gear sizes, while Module is used for metric gears. It really doesn't make sense to convert the module of a metric gear to DP for calculations or gearbox design, because it's much easier to just work with everything in metric.
To calculate the pitch diameter of a metric gear:
Number of Teeth * Module = Pitch Diameter
15t * 0.6mod = 9mm
If you are trying to use this pinion in a custom gearbox, you will probably need to wire EDM cut out (or custom machine) your own custom 0.6mod gears. While 0.6mod is a standard metric gear size, 0.5mod and 0.8mod are much more common sizes to find from suppliers like SDP/SI.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 14-02-2012, 16:50
Phalanx's Avatar
Rookie Year: 1999
Thanks Arthur.
I'm a "software & controls" guy. Mechanical is a little bit of stretch for me.
So in leading by example, I'm stretching myself. Hopefully the students can follow suit.
