Go to Post "Pimp my shopping cart"?!?! - dlavery [more]
Unread 26-01-2012, 17:28
nadya1196's Avatar
nadya1196 nadya1196 is offline
Head of Electronics
FRC #2265 (Fe Maidens)
Team Role: Leadership
Rookie Year: 2010
nadya1196 is an unknown quantity at this point
Maxbotix Sonar Testing
So we have been attempting to get a sonar working on our robot this year, and well we've run into a problem. We wired it by cutting off the male end of the pwm. Then we soldered it black to ground, red to +5, and white to AN (analog).
We looked through their diagrams and information for the maxbotix sonar and we figured out that if we tested it with the voltmeter, it would show about 9.8 mV per inch, but when we tried actually testing it, we couldnt get it working. Any suggestions?
Unread 26-01-2012, 17:54
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Maxbotix Sonar Testing
Are you using the example code to test it? If so, are you receiving anything on Analog 1?
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 26-01-2012, 19:54
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Rookie Year: 2011
Keyreaper is an unknown quantity at this point
Our team has problems with the sensor as well, eventually we just fed the signal/voltage wire (AN Pinout) from the ultrasonic straight to PMW slot one on the analog controller and just pulled the voltage from there, and scaled the output accordingly to get the distance it was reading.
Unread 26-01-2012, 22:01
nadya1196's Avatar
Head of Electronics
Rookie Year: 2010
Actually we are testing it by just using the voltmeter to test if our sonar works in general. We might try running code just through the analog. It is currently plugged into one of the pins that are on the analog breakout in the cRIO. We read that we can get 5 volts from there. So in general, we arent getting any readings when testing if our sonar works.
Unread 26-01-2012, 22:49
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Have you wired 12V to the analog breakout board as shown in the wiring diagram here?
This connection is required to drive the 5V supply on the board.
http://team2168.org
Unread 30-01-2012, 10:36
nadya1196's Avatar
Head of Electronics
Rookie Year: 2010
Yes we have wired the 12v to the analog breakout, and we have measured 5v coming out of it, but it still doesnt seem to be working.
Unread 30-01-2012, 22:38
DonRotolo's Avatar
Back to humble
FRC #0832
OK, so you have +5 V at the "+5V" pin, and Ground on the GND pin, and using a voltmeter between the AN pin and GND you are not seeing any DC voltage, even though the target is, say, around 5 feet away? You should be reading about 0.060 volts for 60 inches.
Unread 30-01-2012, 22:59
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
If this is the EZ-1 you might check on this tidbit I got from the datasheet.
RX – This pin is internally pulled high. The EZ1 will continually measure range and output if RX data is left unconnected or held high. If held low the EZ1 will stop ranging
Use your voltmeter to ensure that the RX pin is indeed being pulled up.
Unread 30-01-2012, 23:13
AKA: Mr Tanguay
Don,
from the datasheet - Outputs 0- 2.55 volts with a scaling factor of 10mV per inch.
That would make it read 0.60 Volts for 60 inches.
