Go to Post Meh, wear safety glasses. - Mike Schreiber [more]
Unread 26-01-2012, 20:52
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
NI Software for FRC 2012
Did a quick search and couldn't find anything.
We have tried installing the new 2012 NI software (from the flat NI flash drive from this year's kit) with no success. We get errors during installation and those ultimately cause the install to fail. Does anyone have any ideas on how to fix this?
Thanks in advance for any help.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 26-01-2012, 21:29
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: NI Software for FRC 2012
The one idea I can throw out is to try copying the installer files to your hard drive then installing from there. Beyond that it would probably be helpful to know what the error(s) are that you are getting.
Unread 26-01-2012, 21:32
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
We got a bad NI flash drive.
So we went down the street to another team and just copied another teams good NI flash drive to a portable hard drive.
Is there a team in your area that you can ping ?
Ed Barker
Unread 26-01-2012, 22:17
AKA: Joe Lee
Rookie Year: 2010
The errors we are getting are something along the lines of a file not being found or not properly installing. We meet again on Saturday morning. I'll post a screen shot of the error then.
Joe
Unread 27-01-2012, 14:02
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
We had a similar problem. The heat of the laptop causes the usb key to change form making the internal contacts separate.
We squeezed the usb key, inserted it into the laptop and held it with fingers while
someone made a copy of all the files. It takes about 5 minutes to copy all the files.
