Go to Post Ironically, I think the best testament to the program [Dean Kamen] founded and his ideals wouldn't be if he won a Nobel Prize. It would be if you did. - Kevin Sevcik [more]
Unread 26-01-2012, 22:03
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
Trapped under a pile of Mechanums
AKA: @doctorfogarty
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Speed PID Function
As far as I know PID Control is normally applied to move a motor, ei. an arm or wheel to a set target/position/distance.
What I NEED to implement is a speed based PID method.
I input a rate.
In my java encoder.java class it lists a method getRate();
I suspect this works by returning......a rate which I could use to set my speed.
from the rate/speed I input... I need to implement a PID method so when voltage drops or a ball passes through the shooter I am using, the POWER % will increase to compensate to allow the shooter to hold a constant SPEED.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
