Go to Post My fondest memory was asking questions about Spirit and Opportunity to a NASA scientist while dressed up in a lion suit. - Adam Y. [more]
Unread 27-01-2012, 08:35
burde1jb's Avatar
burde1jb burde1jb is offline
FRC #4327 (Q Branch)
Team Role: Coach
Rookie Year: 2012
burde1jb will become famous soon enough
Unhappy Sidecar/Jaguar Communications Issue
Rookie Team #4327 Stuck in the mud and trying to get the robot rolling. We turn to you, wise veterans, for guidance.
We constructed everything to the "T" with the Quick Robot Build, the Getting Started with the 2012 FRC Control System, using Labview with the provided default simple robot code. So, basic everything.
Currently receiving the yellow flashing lights on the Jaguar motors which are connected to the CIMs.
The Driver Station verifies communication to the cRIO as well as robot code and therefore allows me to enable the robot. The DS also responds when I use a joystick as provided in the Kit of Parts. I can tell that buttons are being pressed.
The PWM cable is connected (though difficult to seat on the sidecar) in I/O slots #1 and #2. Jumpers were put in the corresponding places. I am receiving power to everything. The CIMs operate fine when directly connected to a battery. I have even tried swapping my two jaguars for two others.
Still the blinking yellow lights.
Any help would be greatly appreciated. We are at our wit's end looking for possible solutions.
Unread 27-01-2012, 10:18
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Sidecar/Jaguar Communications Issue
Did you rework the DB37 cable?
Unread 27-01-2012, 10:28
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
DB37 Cable rebuild instructions
Follow the directions linked above, the only change, flip the female end of the ribbon cable, not the male end. The female end holds up better under the pressure of the vice (tip of the hat to Joe for this suggestion).
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 27-01-2012, 13:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Do you mean you put jumpers on the servo power pins next to the PWM outputs on the Digital Sidecar? While that won't hurt anything, you don't need them for controlling a Jaguar. They are only required when you are connecting a servo.
Describe for us what your Robot Signal Light (either the big amber one or the little green one next to the RSL pins on the Digital Sidecar) is doing.
Unread 28-01-2012, 17:14
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
They are supposed to blink yellowish orange when they are not sending power, red when in reverse, and green when going forward.
Unread 28-01-2012, 17:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
That is not precisely true. When the robot is disabled and they are receiving no signal, they will blink. When they are receiving a signal, they are solid. When full forward is commanded, green, and full reverse, red. To put it another way, when the robot is enabled, the jags do NOT blink.
A blinking jag means no command signal - i.e. a poor pwm cable, a bad pwm connection, a malfunctioning digital sidecar, a bad ribbon cable, or bad code.
Unread 28-01-2012, 17:44
AKA: Voltonless
FRC #3260 (SHARP)
Ohh ok, well today we were having problems because someone over tightened a zip tie and it cut a pwm cable, so check all of them.
Unread 29-01-2012, 10:39
burde1jb's Avatar
Team Role: Coach
Rookie Year: 2012
Could not be more grateful. It was indeed the DB37 cable being backwards. Another local team let me borrow their DB37 cable from last (not the ribbon) and everything worked great.
I reversed the ribbon, but when tightening with the vice, I went too far and bent the metal. When testing, the CIMs began turning with no input in a spastic fashion (jolt forward, jolt back, sporadic behavior).
So I ordered the exact cable model from last year's competition as well as replacements for the male end connector for the ribbon I wrecked.
This ribbon reversal was also a problem with two local teams. Do they pull this stuff on purpose? If so, can we make a rule that it not go against Rookie teams?
