Toggle between two cameras
Hello -
I've written two Axis M1011 cameras into our code. We've deleted the Kinect Skeleton tab and replaced it with a Camera 2 tab which houses our visual display. Now, from my understanding, we cannot use the mouse during the competition, so how can I make a button on a joystick switch between camera tabs? Thanks. |
Re: Toggle between two cameras
If you still want to use a joystick button, it is possible to switch tabs in LabVIEW under program control. Right-click the tab control in the block diagram and choose Create -> Property Node -> Value. Change it from a read to a write, and now you have a way for the program to choose the visible tab. You can send a "which tab to display" value in the Dashboard data from the Robot, and have your custom Dashboard use that value to decide which tab to show. |
Ah, thanks. I've managed to create a "Value" block, however I have no clue how to tell it what I want to do...any assistance?
EDIT - I've changed it from read to write. Now, how do I give it input? (Joystick buttons, for example) Last edited by DominickC : 27-01-2012 at 16:59. |
Any help?
You can certainly use the mouse to switch tabs, and it requires no programming. You may want to change the font to be much larger so that it is easier to hit.
If you want to have another way to switch the tabs, you just program it in. First can you describe how you want to switch -- keys, etc? Greg McKaskle |
While the keyboard/mouse shortcuts are viable options, I was hoping to streamline the process by opening a joystick and using a button. That way the shooter has quick access to both camera feeds..
I'm gonna go ahead and as a relevant question as well - is there a way to get the joystick values to the dashboard without travelling to the robot and back? Reasons being the obvious delay introduced, as well as the waste of resources (however tiny). We could have used it last year, and this year I'm also thinking of a control system utilizing it. In both cases, the delay of going through the robot makes it useless.
DominickC - if you've found the correct property node input to control the active tab, and want to use a joystick button to control it, then what you need to do is, first, make sure you have the joystick value in the cluster you're sending to the dashboard from the cRIO. Then, you can simply use this value in the dashboard project and connect it to the property node to switch the tab. ![]() |
Here's what I've come up with.
Within teleop, I've opened a reference to Joystick 3, and wired the output of button 1 to my bundle. (Pretend I flattened it to a string before it went to the bundle, I realized I left that part out). I then sent it to the Driver's Station. Within the Driver's Station, I've unbundled it. Now, where do I wire the output to? |
I've just wired the value of the joystick being unflattened to the value Vision, which created an orange wire. Will this work for me?
#10
Hope this helps! |
#11
Ah, NOW I get it! Thanks Alan, Greg and NeatNit!
#12
I have never tried to open a joystick connection in multiple apps using DirectInput, which is what the DS uses.
I'm leaving town in an hour, so I'll describe it and I look forward to hearing the results. In the LV dashboard project code, try using the Connectivity>>Input Device functions to open a joystick and read back the buttons. Please note that these VIs aren't quite as flexible as the stuff used for the DS, so once you open a connection, it is not possible to reposition the USB port of the joystick until the DLL leaves memory. This shouldn't be an issue except during development when it causes head-scratching. Greg McKaskle |
