Go to Post It'll take some engineering, but you would have yourself something revoloutionary. Keep innovating! - Greg Perkins [more]
Unread 27-01-2012, 16:57
Codec Codec is offline
Team 1418-Programming & Electronics
AKA: Shayne
FRC #1418 (FIRST Robotics Team 1418)
Codec is an unknown quantity at this point
Exclamation No code error on cRIO with code
We have a new 4-slot cRIO and are attempting to load the demo code onto it. The code deploys sucessfully but the new drivers station has a "no code" error. Attached are the cRIOs configuration and a screen shot of the driver's station. Any ideas?
Name:	Imaging Correct.png
ID:	11598  Click image for larger version
Unread 27-01-2012, 22:36
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: No code error on cRIO with code
Originally Posted by Codec View Post
The code deploys sucessfully...
How are you "deploying" it? Did you Build and then Run as startup, did you Run the Robot Main vi, or did you do something else?
Unread 28-01-2012, 15:33
AKA: Shayne
The cRIO is setup to run code on start up. I used the build all button and then right-clicked on the main.vi and clicked deploy
Unread 28-01-2012, 22:58
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Don't bother with the build button, just click the play button. It builds it and downloads it all in one easy step.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 28-01-2012, 23:17
Software Architect
If you want to put code on the robot to be run on startup, don't "deploy" anything. Right-click on the FRC Robot Boot-up Deployment build specification and choose Run as startup from the popup menu.
