Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 27-01-2012, 20:22
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
Spining wires? cRIO mounting?
I am wiring our robot and i am a new wirer and i way wondering if it was legal to spin the + and - wires together to keep it neeter. I had the old wirer teach me how to wire. Is it ok to mount the cRIO on a piece of lexan that is a little bigger than 1/4 in with zip ties holding the lexan to the frame. I will mount the cRIO using the proper bolts. And what is the best way to sodder the range finder included in the KOP.
