Go to Post Including the Kinect in the kit a parts is actually an evil plan. The programers are going to spend all their time playing with the Kinect. In competition the robot is just to sit there because it will not have a program. :ahh: - FrankJ [more]
Unread 28-01-2012, 10:16
windtakers windtakers is offline
AKA: Blake Dansfield
FRC #3620 (Average Joes)
Rookie Year: 2011
windtakers is an unknown quantity at this point
Labview Motor Ramp up/down voltage
How do you ramp the voltage of a motor in labview.
Unread 29-01-2012, 18:17
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
Rookie Year: 2011
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: Labview Motor Ramp up/down voltage
i would recommend having your drive team do it manually in case you need to accelerate quickly, but to do it with code i would recommend a PID loop that runs once when the joystick has input then resets when the joystick goes back to zero.
2015 MAR District Champions
Unread 29-01-2012, 19:17
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
write the LabVIEW equivalent of this:
Code:
if (new>prev) {
  if (new<=prev+max) {output=new;} else {output=prev+max;}
else {
  if (new>=prev-max) {output=new;} else {output=prev-max;}
prev=output;
"new" is the current cycle's output you want to filter
"output" is the filtered value to output
"prev" is the value you output in the previous cycle
"max" is the max change in output you want to allow per cycle.
Unread 29-01-2012, 20:39
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You could also take advantage the ramp built into the jaguars, either through CAN, or through the (new) preset ramp rate. See Q7 - Q10 in the Jaguar FAQ.
