Go to Post Big Mike (i'm not big you are all just short ;) ) - Mike Schroeder [more]
Unread 28-01-2012, 11:04
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
Rookie Year: 2011
jdh042397 is an unknown quantity at this point
Question 8 Inch rule?????
In the rules, there has to be 8 inches of continuous length on the robot. But does that start on the bumper or the chasis? Cause if it has to have the space cut out for the ball in the middle of the chasis, does it have to start from the bumper or the chasis itself?
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 28-01-2012, 11:06
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: 8 Inch rule?????
There must be 8 inches of Bumper protecting both sides of every vertex (corner) of your Frame Perimeter.
(since 2004)
Unread 28-01-2012, 13:31
shadowdarklight shadowdarklight is offline
FRC #0443
shadowdarklight is an unknown quantity at this point
does the 8" from the vertice *corner* mean the corner of the bumpers meeting out in space, or the 28" by 38" frame of the robot. I can find no absolute evidence in wording to support either one. Help appreciated. guess i'll go reread the rules again
Unread 28-01-2012, 13:47
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
Rookie Year: 2011
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
The rules state that the bumper must cover the "exterior vertices of the Frame Perimeter". I'm 93% sure it means 8'' of the chassis itself.
Unread 28-01-2012, 13:56
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
Q. Does the 8" of bumpers required on each side of vertex include the 3" of the bumper meeting it from the connected side? Or does the bumper need to be 8" of plywood with noodle. In Figure 4-1 it appears that the upper left horizontal bumper is 8", and the vertical is 6" with no plywood on the end.
FRC3931 2012-01-24
A. Per Rule [R27], the Bumper must be at least 8 in. Per Rule [R28], the Bumper must be backed by plywood. Thus, the plywood must be 8 in. The figures in Section 4.1.6 are for illustrative purposes only and are not drawn to scale.
(emphasis mine)
I think this clarifies it pretty well. Good Luck
Unread 28-01-2012, 21:25
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
garyv is right.
go check the official Q&A the posted answered this question several times.
(not exact wording but yeah):
A: The 8in. of frame perimeter directly next to the vertex must be covered by bumpers...
cole?
Unread 28-01-2012, 22:22
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
So the frame has to be 8 inches? I'm sorry, it's just that we can't find the exact answer anywhere.
If the plywood has to be 8 inches, I'm pretty sure there's a rule that all of the plywood has to be supported by the frame. But I just want to double check it.
This is our case: Frame is 27 x 37, the 27 inches side has 6 inches of frame on each side and 15 inches of opening in the middle for the ball. Would we have to change both of those 6 inches to 8 inches? If so, that would kinda suck - we'd only have about 11 inches of opening.
Unread 28-01-2012, 22:25
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Can u split the 8"'s up on one side? Like 5 inches on the Front on both the left and right sides?
https://plus.google.com/photos/10207...CMXV6O3rlcPYPA
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 28-01-2012, 22:42
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
8" from the vertex of the frame perimeter on each side of the vertex of the frame perimeter. Not 8" on the side of the robot. Not 5" on the perimeter + 3" outside the perimeter. 8" from the vertex of the frame perimeter on each side of the vertex of the frame perimeter. The configuration you are proposing should not pass inspection at any event, as it only has 5" on one side of two vertices.
Neal, I would suggest understanding the implications of [R33] as currently written, which says quite clearly that 1) bumpers must be supported by the frame of the robot, 2) as part of that support there is a maximum gap depth or width, and 3) as part of the support the ends of the bumper need to be supported (this particular item was added in Update 2, IIRC). Because of that, you will need at least the equivalent of 8" of frame supporting the bumpers. Yeah, you'd only have 11" of opening on the narrow side. So does everyone else who is smart enough to build their robots 1" undersize to avoid trouble with the size box. At least you're not getting told this at your first regional...
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 29-01-2012, 13:42
neal's Avatar
Neal
Thanks for clarification, Eric. We did make them 8 inches. Now we just hope our grabber works well with 11" opening.
That would be really bad if we never changed it and they told us at the regionals.
Unread 28-01-2012, 22:45
swootton swootton is offline
AKA: Steve Wootton
FRC #4055 (NRG4055)
Rookie Year: 2012
swootton is on a distinguished road
We asked a question on the first Q&A and got a very specific answer. YES the bumper has to be 8" and YES the opening will be 11" or so if you load from the front/rear.
Unread 28-01-2012, 23:12
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
This is how I see it.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 28-01-2012, 23:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
That is correct. 8 inches on each side.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 28-01-2012, 23:38
Is it just me or should the GDC re-write the bumper rules so that they arent so confusing!
2013-Present
2010-2013
  #15   Spotlight this post!
Unread 28-01-2012, 23:40
Andrew Lawrence
Posts: n/a
Does it mean 8 inches for each side of the robot combined, or 8 inches on the robot in a row?
In other words, can we have two sets of 4" bumpers on each vertice (know I spelled it wrong) of our ball intake side making 8 inches total for side, or must we have 8 inches on each of the vertices?
Thanks!
