Go to Post from time to time, we all need a good smack to make us see when we screwed up and did something we shouldn't have. - Andrew Schreiber [more]
Unread 28-01-2012, 15:36
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Exclamation Robot not moving!!!!
We deployed the simple arcade drive code to Crio. When we enable on the driver station and move joystick the robot doesnt move. It gives error.
ERROR <Code> -44003 occurred at WPI_CameraIssue HTTP Request with Authentication.vi>>WPI_CameraIssue Get.vi>>WPI_CameraGet Image Appearance Property.vi>>WPI_CameraGet Numeric Appearance Property.vi>>WPI_CameraGet Image Compression.vi>>WPI_Camera Registry.vi>>WPI_CameraOpen.vi>>Begin.vi>>Robot Main.vi
<time>00:02:15 01/01/1970
FRC: Operation failed due to a communication failure with the camera.
No Change to Network Configuration: "Local Area Connection"<noNICConfig>
I/O unit not detected or not installed correctly.
What is the problem can anyone help us????
Unread 28-01-2012, 16:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Robot not moving!!!!
Those are standard problems. The first is because you don't have your camera plugged in. The second because you don't have the i/o module plugged into your driver station. Neither should affect the robot and whether it moves.
When you enable, what do the lights on your motor controllers do?
Unread 28-01-2012, 19:59
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
It sounds like you're only deploying teleop.vi when you should be deploying Robot Main.vi. After you deploy, open the Driver's Station, select Teleop, and hit Enable.
Unread 28-01-2012, 22:26
zekrysis zekrysis is offline
FRC #3616 (Phenomena)
Rookie Year: 2011
zekrysis is an unknown quantity at this point
also when you run and push on the joysticks check the pwm spots on the dashboard, if you see them change then it means that the robot is accepting the input but for some reason it is not reaching the jaguar, i.e. wire not connected/loose connection etc.
Unread 06-02-2012, 14:04
mayingjunlang95 mayingjunlang95 is offline
FRC #0540
mayingjunlang95 is an unknown quantity at this point
Maybe you should run the main.vi and then try to enable to robot
Unread 07-02-2012, 07:00
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
tilky is an unknown quantity at this point
on our robot, it takes about 8 seconds after enabling before any input will be sent to the robot and it will drive
