Go to Post I would much rather educate the audience than dumb-down the game. - dlavery [more]
Unread 28-01-2012, 17:58
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
How 3620 is rolling for 2012
After seeing these nifty press-fit hubs from West Coast Products, we decided on Colson Performa wheels. Since we want 8" diameter for our chassis set-up, it was necessary to add an outboard bearing holder, machined from a readily available Delrin plug. The WCP hub flange is tapped 10-32 thru to suit standard AM or IFI aluminum sprockets, and we are adapting 25 tooth 5mm pitch Gates timing pulleys to transfer power from the chain driven wheel to one on the other end of the chassis. The adapter uses an AM-0161 bearing hub -- we pop the bearings out and press them into the WCP hub and our adapter to the support the wheel on a 3/8" bolt (dead axle), and press the rest of the '161 into the bored-out Gates pulley. You can see the result in the attached render.
The WCP hub pressed into the 8" Colson nicely with a little effort on our manual arbor.
Richard Wallace
since 2003
Unread 28-01-2012, 18:36
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
Re: How 3620 is rolling for 2012
looks great! West coast products is the jamz
Unread 29-01-2012, 23:00
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Rookie Year: 2011
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Looks good! See you guys at Waterford again!!!
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 30-01-2012, 08:20
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Rich,
When I first looked at the render and saw the pulley and sprocket I thought "sort of like suspenders and belt for a robot isn't it?"
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-01-2012, 15:00
Rookie Year: 1996
A belt-and-suspenders approach seems like a good idea to me.
Seriously, on each side we will drive one wheel using #35 chain from the gearbox, and transfer power to the other wheel using a timing belt. Four wheels on a wide chassis set-up.
Richard Wallace
since 2003
Unread 04-02-2012, 16:49
Rookie Year: 1996
(apologies for double-posting)
Here's a shot of the wheel set-up.
Richard Wallace
since 2003
