Go to Post it isn't about the technology but about the teams working together. Sneaky GDC has done it again. - dtengineering [more]
Unread 03-02-2012, 05:42
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
Rookie Year: 2010
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
Re: Turret/Tower Height
Originally Posted by Siri View Post
Not so much. If you do this intentionally exploiting G44's exception for G28, it's 9 points for them when you get a technical foul under G45.
The analogy from basketball is kinda like offensive charging, only "with intent".
Our regional judge said if you are "playing the game" which is to say, attempting to retrieve and score baskets, then no technical. So there is the human judgement factor. Certainly if you have no ball to shoot, and no ball nearby to retrieve, just hitting the other guy to get a 3 point foul is not wise. You leave too much room for the judge to nail you with the technical.
Talk to your regional head judge and get their direct feedback, especially after they get their final directions from HQ. And buy them coffee the morning of your event.
Unread 02-02-2012, 17:46
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
Rookie Year: 2011
jdh042397 is an unknown quantity at this point
Cool Re: Turret/Tower Height
Team 4063 here is at 40" from the ground to the tip of our launcher. its at a 112 degree angle and makes two points everytime so far.
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 29-01-2012, 20:24
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by squirrel View Post
How do you figure?
We'll do it one better: The ball is above 60" by the time it reaches the vertical projection of our bumper. If we're touching the key, no reasonable defense strategy is going to see an opposing robot "bump" us, so we *hope* that'll do.
Our shooter's top is around 50" as well.
Unread 01-02-2012, 22:59
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
FIRST Team 1296 is at 52" - also seems safe to me
Unread 03-02-2012, 03:36
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Originally Posted by Grim Tuesday View Post
We put ours at 24" to make balancing and going over the barrier easier. If we go to the back of the key, we can't be blocked and we saw no reason to shoot from anywhere else.
Ditto for us (more like 26 probably). It works out for blocking because you want to shoot at something close to 60 degrees anyway, which puts the shot to 60 inches above the ground within 6 inches of your bumper, and we figured no one would want to get that close (if they do, we're in the key and have every right to touch them when wrestling for position). It keeps the CG low, ball storage smaller (exactly 3 balls), the robot lighter, and things a bit simpler.
Unread 29-01-2012, 17:04
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Rookie Year: 2011
Flimsor will become famous soon enough
[quote=n1ckd2012;1115915]We are tall so it's harder block our shots.
QUOTE]
That's not neccesarily true. You could have a tower that's low to the ground and be right up against a taller robot, and all you have to do is just change the angle. The thing you need to take into consideration with the height of the tower is how that affects the center of gravity. You need to make sure its low enough for traversing the bump and/or bridge (if you're doing either). Low cg's will come in especially handy when trying to balance. I'd say a heigh of 30 or 40 is good. That's what we've got.
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 29-01-2012, 22:21
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Hey teams. just wondering where you find the sweet spot as far as the height of your shooter tower. First, Are you using a spinning turret or a tower with a spinning shooter?we have a spinnining robot. How many degrees does it turn, if it does at all?it can turn 360 Finally, how tall are you guys making your tower?we will not have a "tower" I figure it doesnt need to be more than a foot of tower space, but then again maybe some people are storing balls in the tower. What do you guys think?i think your robot will fall over the first time you shoot a ball.
why are you so obsessed with spinning towers?
cole?
Unread 01-02-2012, 15:58
jon-s's Avatar
jon-s jon-s is offline
Lead Designer
FRC #3335
Rookie Year: 2011
jon-s is an unknown quantity at this point
We're avoiding a turret because we'd heard that during the 2006 competition, drivers would get confused by the driving chassis and turret turning independently (using tracking systems). It's also more complication that is not necessarily needed.
I think the main danger with towers is that they can whip around on the bridge, when crossing the barrier, or when your robot is hit by other robots (and can then break off without a significant amount of bracing). They also alter the center of gravity quite a lot. While you may not fall over when shooting, a robot with a tower possibly may when crossing over the barrier (especially when hit by another robot) or more likely, when crossing the bridge.
Our shooter is about 28-30in high right now. We've configured the shooter so that it can't be blocked by other robots. It is still vulnerable to being rammed.
We're aiming to be able to shoot from several places on the field.
Jon. S
Unread 01-02-2012, 18:04
Tylernol's Avatar
Tylernol Tylernol is offline
FRC #2993 (MegaBots)
Team Role: Marketing
Tylernol is an unknown quantity at this point
Our shooter is a one wheel design with the axle mounted at 36 inches high. We're using a small amount of vertical space plus the angled space from the front of the bot to the back (Where our shooter is located) to store the balls.
Unread 01-02-2012, 18:07
waialua359's Avatar
waialua359 waialua359 is online now
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Doesnt most teams have one student driving the robot and the other working the controls?
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
