Go to Post Building a drone during Ri3D is going to be a challenge... - Ginger Power [more]
Unread 01-29-2012, 01:52 PM
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
Code download stops at FTP step
We have the latest Netbeans (7.1) installed and all the latest updates to the FRC plugins. We have re-imaged the cRIO with the latest Java firmware (v43). We are directly tethered to the cRIO using a crossover cable (tried 2 different ones just to make sure). We also have the latest NI Utilities update.
We were able to load a Java program into the cRIO once from Netbeans and have been unsuccessful since. We have re-imaged the cRIO twice (successfully) since we started having the issue and still no luck. The process looks normal until it gets to the "FTP to 10.15.83.2" step. The progress bar at the bottom of the screen does the Cylon raider visor thing and bounces back and forth 3 or 4 times, then goes away. At this point the process appears to hang up.
I'm sure this is probably operator error in some form or another, but need some suggestions as to what else I can try. Re-install Netbeans and the NI Utilities?
It seems like I saw this 2 years ago when we first used Java, but I don't recall what we had to do to fix it.
As always, TIA
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Unread 01-29-2012, 02:58 PM
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Rookie Year: 2012
Chiller is on a distinguished road
Re: Code download stops at FTP step
As always, TIA
Well in the console is there any errors?? If so what are they?
Unread 01-29-2012, 03:00 PM
Rookie Year: 2012
As always, TIA
And since you are able to re-image the cRio successfully it has to be either a Netbeans issue or the plugins issue.
Unread 01-29-2012, 04:33 PM
Unoquadium Unoquadium is offline
The Parlor Generals
AKA: Ilya Rubnich
FRC #0334 (Tech Knights)
Rookie Year: 2010
Unoquadium is an unknown quantity at this point
After you upgrade the cRIO you have to manually restart it to get the FTP server working.
If that doesn't work...
Use the re-imaging tool to check the IP of it, and make sure it matches the one in your Driver Station settings and Netbeans plugin settings.
And if that doesn't work...
Have the Driver Station automatically configure your network settings for you using the "Choose NIC" button.
Unread 01-30-2012, 10:46 AM
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Also check the firewall settings. If still stuck, please post the output - there are networking details embedded that help debug some issues.
Unread 01-30-2012, 08:57 PM
We reinstalled NetBeans and the problem went away. It is working first time, every time now.
Thanks for all the suggestions.
Adam Bryant
Programming Mentor
Team 1583
