Go to Post The fact that it is easy doesn't mean that it is smart. - JVN [more]
Unread 29-01-2012, 21:36
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Red Light Crisis on Spike
Originally Posted by cilginbilgin View Post
So what you are saying is don't wire the spike with the valve , just wire the valve to the solenoid breakout ?.
Yes, exactly. The two wires from a side of the solenoid valve go directly to a 2-pin connection on the solenoid breakout. No need for a spike.
Unread 29-01-2012, 17:37
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
It seems as though your wiring is entirely wrong.
The Spike Relay replaces the Solenoid breakout.
If you choose to use the solenoid breakout, each side of the solenoid can be connected to a separate channel on the solenoid breakout board, no spike needed
If you choose to use a Spike relay, then you would connect the Spikes signal input to the Relay section on the Digital Sidecar using a PWM cable. No solenoid board or module needed; this can be a slight weight savings when using only one or two solenoids.
In addition, the solenoid link you provided is for a 24v solenoid. To use this solenoid, you must connect the solenoid to the solenoid breakout, and power the solenoid breakout from the 24v cRio power supply.
Kettering Motorsports
Unread 29-01-2012, 16:47
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Question Re: Red Light Crisis on Spike
Originally Posted by its da PAT!!! View Post
Ok well there's your problem. The solenoid valve needs to be plugged into the solenoid break out on the crio.
I will start from the very beginning.I have a solenoid valve that is wired into the spike.
Here is the valve that we use.
http://www.festo.com/rep/en-us_us/as...ions_2011b.pdf
Then I wired the pwm output of the spike to 2 ports on the solenoid breakout.
