Go to Post since when is not sleeping, caring more about the robot and such bad for you? If it is how come I didn't get the memo? :ahh: - Sakura141 [more]
Unread 29-01-2012, 14:54
asmsresearch asmsresearch is offline
FRC #3469
asmsresearch is an unknown quantity at this point
Control board on hinged door.
We have electronics on a folding panel. When it is up, the control board is such that the electronics is not accessible. When folded down everything is accessible. Does this obey FRC rules?
Unread 29-01-2012, 16:00
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Control board on hinged door.
We had this in 2009 and 2010. There was no rule back then, haven't seen a rule about it this year.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 29-01-2012, 16:26
FRC #3469
Thanks.
Unread 29-01-2012, 17:33
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Remember R40 and R41. The 120A breaker has to be easily accessible, so it sounds like it can't be mounted on the same board as everything else. Also, your power distribution board has to be easily visible for inspection - in other words, you'll want to be pro-active at competition and make it quick and easy to fold it down for the inspector. Other than that, good luck with the design!
Unread 29-01-2012, 17:42
FRC #3469
My guys are planning to have the 120A circuit breaker available from the outside. It will be available on the back of the board through a portal in outer shell. The board easily folds down for inspection.
Unread 29-01-2012, 17:53
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
asm,
You inspector will need to see all your breakers and all wiring during inspection. If anything goes wrong on your robot while on the field, personnel need to see all LEDs on everything to help diagnose a problem. If they can't see, they can't help you and you may find yourself sitting disabled for a match.
[R41]
The PD Board and all circuit breakers must be easily visible for Inspecttion.
[R55]
By making the diagnostic lights visible, Arena personnel are in a
better position to assist teams.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 29-01-2012, 18:54
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
Are you referring to your operator console or your electronics on the PD board? This will make a big difference in which of these answers is correct.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 29-01-2012, 20:47
DonRotolo's Avatar
Back to humble
FRC #0832
Few operator consoles would have a 120A breaker.
Unread 29-01-2012, 20:58
AKA: Joe Lee
Rookie Year: 2010
OP doesn't mention a 120A breaker.
Joe
Unread 29-01-2012, 22:37
DonRotolo's Avatar
Back to humble
FRC #0832
Sure he does. Emphasis mine
Unread 29-01-2012, 22:38
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
you do not argue with The Don
cole?
Unread 30-01-2012, 13:17
AKA: Joe Lee
Rookie Year: 2010
*cue godfather music*
No. NO! I'm sorry! Please! It won't happen again!
Seriously though, I must've missed that post.
Joe
