Go to Post You'll want to start with P, add some D to help prevent overshoot, and then add some I to help it get to the correct height if it isn't there from the P and D. - AustinSchuh [more]
Unread 30-01-2012, 01:00
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Varying conditions of the balls
So, in our shooter testing and calibration, we discovered that each ball has a different amount of squishyness. Somewhat hard to describe, but to say the effects, the ball we were using for testing went into the basket, and the brand new virgin one hit the ceiling. About 5 feet off. Our conclusion was that balls, throughout the competition will degrade in firmness, but each may degrade in a different way. This makes calibrating a shooter much more difficult. This could and very likely will be a major issue at competitions, when teams tear up balls and new ones are thrown onto the field.
How are you guys, besides the catapult/dumper teams, planning on dealing with this issue? We were prototyping a mechanism that would squish the balls against the side of the robot and detect force, but it was never finished. Has anyone had any luck detecting this decidedly qualitative factor?
Unread 30-01-2012, 10:51
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
Re: Varying conditions of the balls
no but we have figured out that with our shooter having 7ish inches between the 8in wheel and our pvc pipe arond 80 20 works wonderfully
Unread 31-01-2012, 13:03
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
Rookie Year: 2010
one4robots is an unknown quantity at this point
Unhappy Re: Varying conditions of the balls
Team 2530 has also recognized this issue, and we may have dtermined one reason for the variance. The new balls have their coating intact. We believe this makes the ball less squishy because it takes more force to remove the air from inside the ball.
Unfortunately, we have no solutions for how to deal with it. At this point, we are accepting it as a variable outside of our control.
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
Unread 31-01-2012, 14:05
bfk bfk is offline
FRC #2521
Rookie Year: 2011
bfk is an unknown quantity at this point
We noticed this too. Older balls have little breaks (or in one case a 2 inch tear) in the outer skin which allows air to escape, thus decreasing squishiness. Not sure what we can do about it. We thought of shining a light on the balls in our ball lifter and using shininess as an approximation of squishiness, but haven't done anything yet.
It was pointed out by others that the balls in the competition are unlikely to be new every round, more likely that the most beat up ones will be replaced as needed. This will probably lead to most of the balls being a bit chewed up, with a few new and a few on their last legs in each round.
Unread 31-01-2012, 14:13
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Simon we have the exact same problem. Older balls will be a swish shot while the new ones go flying over the backboard. We numbered each ball and sent shot each ball several times and got the same results for each ball.
This can get extremely interesting seeing that by the end of build season our balls will be well worn whereas at competition they will be brand new!
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 31-01-2012, 14:50
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We also numbered the balls in our lab. Each ball has a different level of "squish" when tested with a 12-pound weight and a different diameter. Each ball generally shoots consistently itself, though when compared against other balls the shots are significantly less consistent.
We did manage to get our shooter up to 85%-ish shooting layups off the backboard using a one-wheel shooter from close range.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 01-02-2012, 01:17
AKA: Simon Bohn
Rookie Year: 2010
So now that we have confirmed the problem, lets start brainstorming solutions. My first thought was some sort of lead screw pushing into the ball until a pressure sensor read a certain force, and recording the number of inches of squish. Of course, this is really slow and inconvenient. Anyone else have any ideas? Could we pre-mash up a ball and get it ready to shoot and be consistent?
The other questions to ask are: What curve is there in the squish? Is there a point where balls move from 'hard' to 'squishy'? Or is it some sort of curve, or linear progression?
Unread 01-02-2012, 02:05
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Has anyone tried putting their intake rollers (if that is your chosen method), on springs and measuring deflection as the balls get sucked in?
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
