Go to Post So, you're saying there's a correlation between hard work and success? Who woulda thunk it?! - Tom Bottiglieri [more]
Unread 30-01-2012, 11:27
ksanger's Avatar
ksanger ksanger is offline
FRC #0211 (MaK)
Rookie Year: 2010
ksanger is on a distinguished road
Standalone Java Image Application
We are trying to build a standalone Java Image application that would read the camera, process the image, and post data to the Smart Dashboard. For debugging we would like to read in one of the sample images. However our code crashes using the RGBimage("filename.jpg") with a class not found exception.
We haven't found any examples of standalone java applications. Only ones that use the cRIO. Can anyone help?
Here's our simple program.
package javaimagesample;
import edu.wpi.first.wpilibj.image.ColorImage;
import edu.wpi.first.wpilibj.image.NIVisionException;
import edu.wpi.first.wpilibj.image.NIVision;
import edu.wpi.first.wpilibj.image.RGBImage;
import java.util.logging.Level;
import java.util.logging.Logger;
* @author l241870
public class JavaImageSample {
* @param args the command line arguments
public static void main(String[] args) {
// TODO code application logic here
ColorImage image; // next 2 lines read image from flash on cRIO
try {
image = new RGBImage("/10ft2.jpg");
} catch (NIVisionException ex) {
logger.getLogger(JavaImageSample.class.getName()). log(Level.SEVERE, null, ex);
Here is the debugger output showing we error on the line
We have also tried defining the complete path to the image too.
debug:
Exception in thread "main" java.lang.NoClassDefFoundError: com/sun/cldc/jna/TaskExecutor
at edu.wpi.first.wpilibj.image.NIVision.<clinit>(NIVi sion.java:29)
at edu.wpi.first.wpilibj.image.Image.<init>(Image.jav a:24)
at edu.wpi.first.wpilibj.image.ColorImage.<init>(Colo rImage.java:16)
at edu.wpi.first.wpilibj.image.RGBImage.<init>(RGBIma ge.java:32)
at javaimagesample.JavaImageSample.main(JavaImageSamp le.java:27)
Caused by: java.lang.ClassNotFoundException: com.sun.cldc.jna.TaskExecutor
at java.net.URLClassLoader$1.run(URLClassLoader.java: 366)
at java.net.URLClassLoader$1.run(URLClassLoader.java: 355)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.j ava:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:4 23)
at sun.misc.Launcher$AppClassLoader.loadClass(Launche r.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:3 56)
... 5 more
Java Result: 1
BUILD SUCCESSFUL (total time: 18 seconds)
