Go to Post to all of the people who are on robotics, I thank you for giving me the chance and happiness that i had never had before. robotics has been the happiest thing i have ever done in my life - gondorf [more]
Unread 30-01-2012, 15:38
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
LV-MaxSonarŽ-EZ1 Sonar Sensor
I am reading the sonar sensor spec and found the following sentence:
Each 49mS period starts by the RX being high or open
Does it mean if I connect the RX pin to a digital output channel, I can inhibit the ping indefinitely by pulling RX low until I need to read the range. Then I would raise RX back to high and wait 50ms before reading the analog value? Without doing this, it seems the sonar sensor will ping continuously at approx. 50ms period. Am I reading this correctly?
Unread 30-01-2012, 17:30
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: LV-MaxSonarŽ-EZ1 Sonar Sensor
That's how I read it.
Unread 30-01-2012, 21:59
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, exactly. A valuable feature of the sensor, particularly when you have a lot of pinging around you.
