Go to Post Just remember, a spark of inspiration can produce a lifetime of success. - JoeXIII'007 [more]
Unread 30-01-2012, 20:40
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
How often is code run in teleop?
Hello -
I'm looking to migrate some of my code which I have written into Teleop.vi (mainly moving motors and servo's with buttons) into Periodic Tasks.vi, mainly to cut down on the Watchdog errors we get periodically.
However, I know that I must put the code within a while loop and tell it how long to wait till the loop executes again.
If I'm getting the value of a joystick button, and if someone is holding the button then we are changing a case structure to true which moves a servo +1 degree, how much wait between each iteration of the code will result in the fluid motion we see within Teleop.vi?
Thanks.
EDIT - Also, is the Select function more efficient than a Case Structure?
Unread 30-01-2012, 20:48
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: How often is code run in teleop?
Roughly 20ms.
Unread 30-01-2012, 20:59
Ether is correct. But I posted a notice to the CPU usage thread pointing out that the loops have no delays and are probably running hundreds of times in the 500ms and are maxing out the CPU.
Greg McKaskle
Unread 30-01-2012, 21:22
FRC #0023 (PNTA)
Rookie Year: 1620
Awesome, thanks.
Now, how can I set code to write a value, sleep/wait for x ms, then write another value?
Unread 30-01-2012, 21:24
Ether's Avatar
Rookie Year: 1969
Awesome, thanks.
Use a state machine or a parallel loop (thread).
Explained here:
http://www.chiefdelphi.com/forums/sh...96&postcount=3
... and here:
http://www.chiefdelphi.com/forums/sh...21&postcount=6
