Go to Post 12 is a dozen, 13 a bakers dozen...47 will be a delphi. - Kimmeh [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 30-01-2012, 23:17
gspais gspais is offline
FRC #2191
gspais is an unknown quantity at this point
Hole Locations On Chassis Channel AM 0202
FYI: The Inventor file for the 35" long channel (AndyMark part no. AM 0202 in the 2012 chassis drive base kit) may have some mislocated holes. On the actual steel piece, the center of the first axle hole starts 3.125" from each end. In the Inventor file, the center of the first axle hole starts 4.125" from one end and the other hole starts 3.125" from the other end. It's easy enough to fix by editing the sketch of the holes and re-dimensioning the distance. This was discovered when a CAD top view of First Team 2191's chassis assembly showed the wheels/axles as being non-colinear on each side of the robot.
