Go to Post Eh, typical FIRST team, take something awesome and make it even better. - rsisk [more]
Unread 31-01-2012, 12:53
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
Team Role: Coach
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Difference between Shift Register and Feedback Node
This is a general question about LV programming, but would love to hear some opinions on this...What is the difference between using Shift Registers and Feedback Nodes? They appear to be functionally the same, just drawn differently in the Do Loop. Is there performance differences between the two?
I did some poking around NI website with this question and found some great debates about their use, but most of the discussion were referencing a few rev's back of LV. Is there a definitive answer on when to use one over the other for the latest revisions of LV?
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 31-01-2012, 13:17
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: Difference between Shift Register and Feedback Node
They are pretty much the same. I used them at different times more from a personal preference. I use shift reg more just because I have been programming with LabVIEW from the early 90's and grew up with shift reg.
I use shift reg 3/4 of the time.
I use feedback nodes to save space on the block diagram and to keep from running wire all cross my block diagram. I most only use the feed back nodes pointing to the right. I do not like to have any wires going from right to left. So in those cases I use shift reg. These are all personal preferences and not the same for everyone.
I have never seen any real speed differences that really matters.
The feedback mode dose have some built in functions that to do the same with shift reg you would have to add a little code. But anything you can do with a feed node you can do with a shift reg and a little extra code.
There are some extra initialization setting (configuring) that the shift reg does not have, but I never had a need for them.
Which one you use is up to YOU.
Omar
Unread 31-01-2012, 16:00
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
Rookie Year: 2011
tilky is an unknown quantity at this point
i hope you aren't using shift registers under teleop
Unread 01-02-2012, 00:31
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
Rookie Year: 2010
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Single run loops are a common design when using uninitialized shift registers. I have personally stated to move away from this, towards feedback nodes. This is mostly due to some misunderstandings with junior programmers. I find that feedback nodes offer more information at first glance. This is particularly important for code review. This however, comes with the risk of sloppy looking code. I believe uninitialized shift registers, used in single run loops have some overhead due to the loop. I am unsure of how the compiler optimizations affect this. I often will use them interchangably.
Mike B
Unread 01-02-2012, 08:50
Omar's Avatar
We use shift reg all the time in teleop.
The number one way I use shift reg is in single loop while loop just to store a value for later use.
Omar
Unread 01-02-2012, 08:51
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Simply, shift registers are just a way to pass a value from one iteration of a loop to the next iteration of the loop. They require a "host loop" that they connect within.
Loop iterations (0 is the initial value passed into the shift register)
0 1 2 3 4 5 6 7
Output (This looks weird, but due to the design of the shift register, the output comes before the input, left to right)
0 0 0 1 2 2 3 0
Input
0 1 2 2 3 0 7
Final output 7
A feedback node is basically a shift register without the loop. The shift register takes and delays the incoming signal one iteration of the vi. This would be used in Teleop, where you can't have loops.
VI iterations
0 1 2 3 4 5 6 7
Input
0 0 1 2 2 3 0
Output
0 0 0 1 2 2 3 0
Last edited by zaphodp.jensen : 01-02-2012 at 09:00. Reason: Added more information.
Unread 01-02-2012, 16:33
MotorHead's Avatar
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
Team Role: Coach
Could you explain more about this? Post a code example perhaps. I was under the impression as well that you could not do this since the shift register involved a loop and you didn't want the loop tying up telop. In the past, I have written information to a Global Variable and let a loop inside of Periodic Task access the value.
Jeff Beltramo
Team #1922
Unread 01-02-2012, 16:50
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Our team uses while loops with shift registers to run all of our inputs and outputs. Inside each loop is a case structure with an enum for 3 modes, which are init, run and end. All the code that would normally be placed in the begin VI is placed in the init case, and then that case is run in begin. In run is all of our code that is used at runtime. In end it the code that is normally located in finish. This shift registers are used to transfer the references between the 3 states. This means that we do not need to use refnums which saves some resources.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 01-02-2012, 17:48
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The trick is that the stop of the while loop is wired to a true constant, so that the loop only runs once.
Unread 02-02-2012, 00:25
SuperS_5's Avatar
FRC #1219
Rookie Year: 2010
Just be careful with Enums like this. This is very common practice BTW, and one method to keep your code isolated. Your action Enum, (Init|work|end) should always be a TypeDefd control. This also presents the possibility of the constant value automatically changing if the typedef is updated. I typically will write the desired value as a BD note, next to the Enum constant.
Mike B
