Go to Post I do this for the people...the kids, the mentors, and especially, with all my heart, the volunteers. Thank you for all you do. - Andy Grady [more]
Unread 01-31-2012, 01:11 PM
2869Robotics 2869Robotics is offline
FRC #2869
2869Robotics is an unknown quantity at this point
Camera
When I try and run this code, I get the following exception. I am programming in Java, so why does my exception include something relating to WindRiver? I'm trying to store an image on the cRIO and then I plan to retrieve the images using FTP.
AxisCamera cam = AxisCamera.getInstance("192.168.0.90");
cam.getImage().write("image.jpg");
>>>>ERROR: The object is in an incompatible mode: No content-length token found in packet ...in ReadImagesFromCamera() in C:/WindRiver/workspace/WPILib/Vision/AxisCamera.cpp at line 281
[cRIO] Default disabled() method running, consider providing your own
[cRIO] edu.wpi.first.wpilibj.camera.AxisCameraException: No image available
[cRIO] at edu.wpi.first.wpilibj.camera.AxisCamera.getImage(A xisCamera.java:292)
[cRIO] at edu.wpi.first.wpilibj.templates.RobotTemplate.oper atorControl(RobotTemplate.java:82)
[cRIO] at edu.wpi.first.wpilibj.SimpleRobot.startCompetition (SimpleRobot.java:118)
[cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase .java:156)
[cRIO] in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callSta rtApp(64)
[cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO] at com.sun.squawk.Isolate.run(1506)
[cRIO] at java.lang.Thread.run(231)
[cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
Unread 01-31-2012, 02:07 PM
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Camera
You get the windriver error because the java files are actually wrapped C-code. Where is your camera plugged in? And did you do the setup utility so it can create the FRC user?
Unread 01-31-2012, 04:42 PM
detruby detruby is offline
Dave Truby
AKA: Dave Truby
FRC #4145 (Wolf Pack)
Rookie Year: 2012
detruby is an unknown quantity at this point
Re: Camera
Follow the directions to change the camera configuration to allow anonymous connections.
Unread 01-31-2012, 05:56 PM
FRC #2869
Re: Camera
I plugged the camera into port 2 of the cRIO. I realize that we are supposed to connect it into the router/bridge but I have close to no networking experience. I reset the camera and I manually went into the camera and added a user frc password frc. Would I still need to run the camera setup tool? How would I change the camera config to allow for anonymous connections?
Unread 01-31-2012, 06:32 PM
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Camera
There's a check box on one of the pages. I don't have the camera handy, so I can't confirm where.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
