Go to Post Vex has helped to shape me into what I am today. - thefro526 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:26
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Rule M14
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 1/9/2000 7:20 PM MST
General Question For the Peanut Gallery:
What do you make of rule M14 (page 16 The Robot Appendix)?
Taken literally, this rule implies that at some point in time (perhaps at check in perhaps at inspection at you first competion, perhaps at the time you put your robot in the box), your robot is FROZEN -- no improvements at all can be made.
I know that some folks out there are saying, yes that is exactly what FIRST was ment to be, but I urge you all to read on.
Consider this. Suppose I have an aluminum part that I discover breaks every third match, but sadly, I discover this fact after the magic moment discussed above.
According to rule M14:
'...FUNCTIONALLY IDENTICAL replacement parts are allowed. FUNCTIONALLY IDENTICAL implies a part that is of THE SAME GEOMETRY, MATERIALS, ETC. AND NOT AN IMPROVED DESIGN.'
This rule seems to forbid doing anything to that part except replace it when it breaks! It seems to forbid something so easy as re-making the part out of steel for example.
Am I missing something?
Let's talk this one out a bit.
Joe J
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
My Favorite rule. :) Useless member Rules/Strategy 15 01-03-2003 00:44
Proposed New Rule M11 Joe Johnson Rules/Strategy 14 04-02-2003 14:41
Rule C1 Justin Stiltner Rules/Strategy 9 05-01-2003 22:59
Do away with the 2-minute rule! archiver 2000 3 23-06-2002 23:17
1 coach rule Mike Soukup Rules/Strategy 14 07-01-2002 22:27
