Go to Post And - I would never ever underestimate a rookie. Ever. - JaneYoung [more]
  #16   Spotlight this post!
Unread 01-02-2012, 17:53
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Converting 12v to 24v
Are you saying that the bell is not doing work? Is not a solenoid? How was the bell legal in 2010?
2010 Robot Rules...
<R53> Items specifically PROHIBITED from use on the ROBOT include:
A. Electric motors and/or servos different from, or in addition to, those in the KOP, with the exception of those specifically permitted by Rule <R52>.
B. Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
Al
WB9UVJ
www.wildstang.org
________________________
  #17   Spotlight this post!
Unread 01-02-2012, 18:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
The bell is:
  • electrical,
  • an actuator,
  • not a solenoid, and
  • doing work.
There was no prohibition against electric actuators in 2010, except that motors other than those listed were illegal, and solenoid actuators were illegal. Think of it as a custom circuit. (It must still comply with all other rules.)
(The 2012 rules are somewhat different, as noted above.)
  #18   Spotlight this post!
Unread 01-02-2012, 23:02
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Originally Posted by Tristan Lall View Post
The bell is:
  • electrical,
  • an actuator,
  • doing work.
A solenoid is simply a coil of conductive material (Technically, there are many accidental solenoids on robots every year, but those are not actuators). The bell pictured clearly utilizes a pair of solenoids wrapped around the iron core. As stated it is an actuator. The actuation occurs as a result of current passing through said solenoids, thus, it is a solenoid actuator.
  #19   Spotlight this post!
Unread 01-02-2012, 23:37
Rookie Year: 1999
A solenoid is a particular kind of wire coil: it's oriented such that it produces a uniform magnetic field within the core.
For sufficiently lax definitions of "uniform", sure, we've got all sorts of solenoids. But then you get into perverse situations where every motor winding is a rudimentary solenoid, and thus the motor is a solenoid actuator as well as a motor. (I, for one, certainly don't want to believe that this is what FIRST intended. It kind of flies in the face of conventional nomenclature, both for motors and solenoids.)
For the bell and the clutch, if the windings are squarishly wound around a squarish core (in cross-section), the magnetic field will likely be very non-uniform. That's also a poor approximation of a solenoid.
Contrast this with an ordinary solenoid actuator, which does indeed contain a tightly-wound cylindrical coil of wire, designed to provide a uniform magnetic field within the core.
I don't really see any way to judge from the rules that the level of non-uniformity found in the clutch's magnetic field is substantially different from the non-uniformity of magnetic field produced by a motor's windings.
  #20   Spotlight this post!
Unread 02-02-2012, 07:44
Unsung FIRST Hero
Rookie Year: 1996
Tristan,
The bell was not legal in 2010. And there is no way anyone can convince me it's a custom circuit. The bell meets none of the criteria below that would make it allowed. And in all likelihood I would also rule it illegal under R02.
8.3.7 Motors & Actuators
<R52> Motors specifically permitted on 2010 FRC ROBOTS include:
A. All motors, actuators, and servos listed in the 2010 KOP,
B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the KOP),
C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D. One, two, or three additional 2˝” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to five, and no more, 2˝” CIM motors can be used on the ROBOT.
E. Identical one-to-one SPARE PARTS for motors, actuators, and servos provided in the 2010 KOP that may have failed or become damaged.
<R02> ROBOT parts shall not be made from hazardous materials, be unsafe, or cause an unsafe condition. Items specifically PROHIBITED from use on the ROBOT include (but are not limited to):
B. Speakers, sirens, air horns, or other audio devices that generate sound at a level sufficient to be a distraction or hindrance affecting the outcome of a MATCH
Al
WB9UVJ
www.wildstang.org
  #21   Spotlight this post!
Unread 02-02-2012, 13:28
Rookie Year: 1999
Remember that in 2010, the electric motor/acutator rules specified what was allowed (in terms of motors), what was not allowed (in terms of motors and solenoids), and was silent about all other types of electric actuators. The 2010 rule stated neither prohibition nor permission, and thus, per standard practice, it could be used if it also conformed to all other rules. I don't think we would disagree that—at least since the demise of the additional hardware list about a decade ago—teams can use parts that are not mentioned, provided they comply with all rules.
(For everyone else following along, be warned that the rule is different in 2012, because it directly addresses all actuators.)
And if not a custom circuit, what is it? It's a part which is legally connected to the robot electrical system (assume it runs through a Spike), but which is not specified in any official drawings/manuals. It affects no output devices nor power pathways, interferes with no other robots and is a COTS item. It's the same as an LED ring light in that respect.
Besides, other than the safety rules addressed below, what 2010 rules would you use to regulate this bell if it was neither a prohibited actuator, nor a custom circuit?
The applicability of 2010's <R02B> (and I guess <R03A>) would depend on the implementation. It could be a factor if the bell was operating at or above its design voltage, and was unmuffled. Then again, if a team used a 24 V bell at 12 V, or stuffed a rag in the bell as a muffler, or just used the actuator part without the bell, it could easily conform to <R02B>.
  #22   Spotlight this post!
Unread 02-02-2012, 14:53
Unsung FIRST Hero
Rookie Year: 1996
Tristan,
The above rule lists the only devices that could be used on the robot. There was no hidden or silent list of actuators that could be used. There is nothing that would be allowed if it wasn't on the list. There was no custom circuit that could be or act as an actuator. The list was the only actuators that you could use.
From the Q&A...
"Re: clutches
Posted by GDC at 01/21/2010 10:54:45 pm
There is no rule specifically prohibiting the use of clutch mechanisms on the ROBOT. However, these devices may not be used if they contain electric motors and/or servos different from, or in addition to, those in the KOP, solenoid actuators (per Rule <R53>) or pneumatic actuators (such devices are not explicitly permitted by Rule <R72>, and therefore violate Rule<R71>).
Simply put: if the device utilizes an electric solenoid to provide mechanical motion for the device, it cannot be used."
In addition to the above, the GDC also ruled that relays (solenoids with electrical contacts) other than Spikes could not be used on the robot even if fully contained in a custom circuit and meeting all other robot rules.
The only movement on the GDC's part that even comes close was to allow an electromagnet that holds something in place while energized and simply released it when the current was removed.
Al
WB9UVJ
www.wildstang.org
  #23   Spotlight this post!
Unread 02-02-2012, 16:31
Rookie Year: 1999
For 2012: "The only motors and actuators permitted on 2012 FRC Robots include...". This is exclusive with respect to motors and actuators.
For 2010: "Motors specifically permitted on 2010 FRC ROBOTS include..." and "Items specifically PROHIBITED from use on the ROBOT include...motors [not from the KOP or otherwise permitted]...[and] solenoid actuators". This is exclusive with respect to motors and solenoid actuators, but not exclusive with respect to actuators that are neither motors nor solenoids.
That non-exclusivity is the important fact. If the bell or clutch was not a solenoid or motor, then it would not have been prohibited in 2010. (And if it was a solenoid or illegal motor, it would have been prohibited.)
Since the 2012 rule is exclusive, it works the opposite way: if the bell or clutch is a solenoid, then it must meet the requirements for solenoid actuators. If it is not a solenoid actuator (or a legal motor), it is prohibited.
The rules provide no reason to believe that a device can't simultaneously be a custom circuit and an actuator. (Indeed, having both sets of constraints apply simultaneously is desirable...otherwise teams could use legal actuators without regard to the specific electrical conventions required of custom circuits.) Though admittedly the rules aren't clear about this, for 2012 there isn't really any reason why any motor couldn't be considered a custom circuit...there's no significant discrepancy between the motor requirements and custom circuit requirements. I doubt this is necessarily what FIRST intended, but at least it doesn't conflict.
From the Q&A...
"Re: clutches
I'm contending that it doesn't meet the definition of solenoid, and therefore doesn't conflict with the rule or the Q&A quoted above.
Solenoids would have been illegal in 2010 as you and the GDC stated.
  #24   Spotlight this post!
Unread 03-02-2012, 00:36
AKA: Alan Wells
FRC #1350 (Rambots)
It'a a 2 dimensional drawing, the winding could be pentagonal for all I know. The only thing I can tell from the drawing is that what I can see of the coil is fairly uniform.
Additionally, even by your questionably strict definition of a solenoid, the sectioned clutch image you posted depicts what is quite clearly a solenoid. one side of the clutch is connected to a V-belt pulley (green) the other side is (yellow) is the armature of the solenoid which appears to move on a double keyed shaft. The solenoid winding are stationary and contained within a frame (grey). When the solenoid is energized, the armature is pushed out of the center of the solenoid winding to increase the friction between it and the green side of the clutch. The windings are co-axial with all components of the clutch and are wound as a single coil around the armature. That is, the coil of the clutch is a uniform, tightly wound cylindrical coil designed to provide a uniform magnetic field within its core.
  #25   Spotlight this post!
Unread 03-02-2012, 00:55
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
To preform (my understanding) what your trying to accomplish without breaking any rules or even flirting with any of them. You might look into pneumatic clutches. If your not using any pneumatic's anywhere else on the robot it might not be a good solution for your problem. Just an idea.
  #26   Spotlight this post!
Unread 03-02-2012, 02:28
Rookie Year: 1999
You may be right about the coil arrangement in the diagram. It could be toroidal, or it could be cylindrical, with several layers. If it is cylindrical, you could definitely have a viable solenoid within the bore of the clutch.
But, notice that the green armature does not reside inside the core of the windings. That's because it's arranged just like a conventional electromagnet (where the disc-shaped faces of the coil housing and armature attract), rather than a solenoid actuator (where the armature would be attracted/repelled by a portion running through the core of the winding).
And that goes back to the previous question: if we have a solenoid in an actuator, is it necessarily a solenoid actuator? If we have a decent solenoid in a motor winding, but the motor's principle of operation doesn't depend on the thing being a solenoid, is the motor a solenoid actuator? Same question here—even if we have a decent solenoid, the principle of operation of the clutch depends only on the external magnetic field. So why would this one be a solenoid actuator, if the motor isn't?
There's another layer of complexity: there's what I think, and then there's what I think a team could reasonably think. In this case, I think it's not a solenoid actuator. But I do leave open the possibility that a team might be under a reasonable impression that it is. (That would be highly dependent upon the situation, and the explanation and documentation provided.) I'm not saying this to be argumentative—I've got a better reason. It's the principle that a team that shows up to a regional having bought and installed an electromagnetic clutch should get the benefit of the most lenient yet precise interpretation of the rules. After all, the inspectors aren't trying to make teams fail—quite the opposite.
An additional layer of complexity is what the GDC thinks. As has been demonstrated repeatedly over the past decade or so, the Q&A operates on a different level to inspectors and teams. I'd venture to say it's a less practical level, and frequently a less creative level. Oftentimes a Q&A response will presuppose limitations that aren't logically required by the rules. Nevertheless, the inspectors need to balance what the Q&A is saying with what their understanding of the rules' demands. (When those conflict, there's an ethical decision that may involve equitable remedies outside of what the Q&A explicitly instructs.) I raise this issue, because what I say here (generally) represents my opinion in a vacuum, and not necessarily what I would rule in a competition setting where other factors (beyond the rules) are at work.
[R68] and [R71] would prohibit pneumatic clutches.
  #27   Spotlight this post!
Unread 03-02-2012, 02:40
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
Look around the web and you find many definitions of solenoids. One thing that many have in common is that it's coil of wire than when energized creates a magnetic field that causes a linear motion. So yeah I'd say a magnetic clutch would fall under the solenoid rules and 10w at 12v is not going to create a enough force to transmit very much torque.
For our kicker for Breakaway we created a created a transmission based on the AM super shifter. Basically we built a custom case and left out the high idler gear. In the low gear position it transmits power and shift it into the "high" gear and it freewheels. Because it was under a lot of torque we had to shift it with a lever arm to generate enough force.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
  #28   Spotlight this post!
Unread 03-02-2012, 07:55
Unsung FIRST Hero
Rookie Year: 1996
Tristan,
You are going way out on a limb here.
"If the bell or clutch was not a solenoid or motor, then it would not have been prohibited in 2010." The bell is a solenoid and so is the clutch you show. I have worked on a couple of hundred of these air conditioning clutches over the years. The clutch plate is pulled by the magnetic field set up by the electric current. The pull mates a frictional plate with a metallic plate to lock the pulley to the drive shaft of the compressor. If you stick your finger between the plates when you energize the coil it will get pinched.
"This is exclusive with respect to motors and solenoid actuators, but not exclusive with respect to actuators that are neither motors nor solenoids." What actuator is neither a solenoid or a motor or a pneumatic part?
"Since the 2012 rule is exclusive, it works the opposite way: if the bell or clutch is a solenoid, then it must meet the requirements for solenoid actuators. If it is not a solenoid actuator (or a legal motor), it is prohibited." Exactly!
"Though admittedly the rules aren't clear about this, for 2012 there isn't really any reason why any motor couldn't be considered a custom circuit...there's no significant discrepancy between the motor requirements and custom circuit requirements. I doubt this is necessarily what FIRST intended, but at least it doesn't conflict." How can you draw this conclusion from both the motor list that you state is an exclusive list (excludes all motors not on the list) and from the custom circuit rules which prevent any custom circuit from direct control of a motor?
[R47]
Custom circuits shall not directly alter the power pathways between the battery, PD Board, speed controllers, relays, motors, or other elements of the Robot control system (including the power pathways to other sensors or circuits).
So what exactly are you thinking could appear on an FRC robot that is neither a solenoid nor a motor nor a pneumatic part, that would be in your mind, a legal actuator?
Al
WB9UVJ
www.wildstang.org
  #29   Spotlight this post!
Unread 03-02-2012, 08:18
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
I don't see the loop hole but I'm not the GDC. Many years ago we prototyped a friction clutch that only used a Hitec servo to hold. It can be done. If you have air on the bot a friction clutch is easier. A little 3/4" piston is all that is needed.
With out a clear ruling from the GDC find another way. If this is for a catapult, there was a video earlier that showed a team using a eccentric cam to operate the catapult.
  #30   Spotlight this post!
Unread 03-02-2012, 09:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Is a speaker a solenoid?
Not all electromagnets are solenoids. I looked at a few definitions of "solenoid" just now, and the common feature was that they all either moved an armature inside the coil, or moved a coil between permanent magnets. From what I can see, neither the bell nor the magnetic clutch fits that category.
What matters in the end is not what I think "solenoid" means, or what you think it means, but what the GDC thinks it means. Until someone asks and gets a clear answer, I'm personally going to be conservative and eschew electromagnets in general unless they satisfy the motor or electric solenoid actuator rules.
