Go to Post Maybe we should put one of those advisory signs: "Don't try this at home ... or at Robotics competitions" - Franchesca [more]
Unread 31-01-2012, 20:54
sctjkc01 sctjkc01 is offline
FRC #3181 (Pittsford Panthers)
sctjkc01 is an unknown quantity at this point
SmartDashboard custom Widgets not appearing...
For some reason, I can't get the custom Widgets I'm adding to show up in the View>>Add list. I'm dropping the Netbeans-compiled JAR in the folder C:\Program Files\SmartDashboard\extensions. Am I doing something wrong? Is there some way to access the SmartDashboard's Java console to see if it was just bad coding on my part?
Unread 01-02-2012, 11:58
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
Rookie Year: 2011
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: SmartDashboard custom Widgets not appearing...
I have the exact same problem. I copied the source code word for word from the extension tutorial, added the JAR, and it still did not show up.
Unread 01-02-2012, 12:47
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
Rookie Year: 2007
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
You can run a JAR in the Windows command prompt. Figure out where your Java binaries are, mine are in
Code:
C:\Program Files (x86)\Java\jdk1.6.0_16\bin
Then add these to your path.
Then open cmd.exe and
Code:
cd C:\Program Files\SmartDashboard
java -jar SmartDashboard.jar
Unread 02-02-2012, 18:57
On closer inspection, this is an issue on their part... that is, whoever made the SmartDashboard:
Code:
Searching Folder:.\lib
Adding Jar:.\lib\jcommon-1.0.16.jar
Adding Jar:.\lib\jfreechart-1.0.13.jar
Adding Jar:.\lib\junit-4.8.2.jar
Adding Jar:.\lib\NetworkTable_Client.jar
Searching Folder: .\extensions\lib
Adding Jar:.\extensions\lib\javacpp.jar
Adding Jar:.\extensions\lib\javacv-windows-x86.jar
Adding Jar:.\extensions\lib\javacv.jar
Adding Jar:.\extensions\lib\WPIJavaCV.jar
Searching Folder:.\extensions
Adding Jar:.\extensions\3181SmartWidgets.jar
Adding Jar:.\extensions\WPICameraExtension.jar
Searching Jar:.\extensions\3181SmartWidgets.jar
Custom Widget:VerticalBar
Searching Jar:.\extensions\WPICameraExtension.jar
Custom Static Widget:WPICameraExtension
Custom Static Widget:WPILaptopCameraExtension
Our Jar is .\extensions\3181SmartWidgets.jar, and it's obviously searching the Jar, and it's obviously finding the class (which is also an effective copy-paste from the tutorial) however it's not showing up in the menu!
Unread 02-02-2012, 19:09
Hjelstrom's Avatar
Hjelstrom Hjelstrom is offline
Mentor
FRC #0987 (High Rollers)
Hjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond repute
Ok, I don't know if this will help but we struggled a bit with this the other day too. Here are some thoughts:
Does your custom widget inherit from "Widget" or "StaticWidget"? The only ones that show up in the menu are "StaticWidgets". To use "Widgets", have your robot send some data, then convert the widget that is automatically created into yours.
It took us a few trys to figure out where to put the extension JAR file but it looks like you've got that solved.
We were initially using NetBeans 7.1. JAR files we created with it did not work for us with the SmartDashboard. The docs say to use 6.9 but it was hard to find it on the NetBeans site.
Even though we had some hurdles to overcome, we're extremely happy with the SmartDashboard. It is terrific.
Unread 02-02-2012, 21:58
Oooh, OK. Now I'm understanding it clearly.
Yeah, we've got a Widget. Now I see why.
