Re: Examples of wide-based robots using traction and omni wheels
Make sure to report back once you do test on carpet... it really can make the difference in how your drivetrain performs
Just remember, you will be easy to push with only two wheels providing traction. Consider making your traction wheels wider. (IFI 2'' wheels)
http://www.vexrobotics.com/ifi-wheel.html |
2) Our strategies are to be fast, maneuverable, and for the most part stay away from opponents/areas where we get penalized. However, we do have a strong defensive strategy which will be useful no matter the opponents we go against. |
Back in 2006 FRC322 had a wide chassis and the traction/omni combo you are looking for, they seemed to move on the field rather quickly:
http://www.chiefdelphi.com/media/photos/23148 http://www.thebluealliance.com/team/322/2006 |
Not true. In fact, we went through a design change already because with a well balanced wide robot with pneumatic wheels at the corners inflated to max pressure, the robot had a very hard time turning.
My team used a wide robot with kit wheels in the front and omni-wheels in the back for the 2008 season, after doing this in a long configuration had worked out well the year before. In the end I think the robot ended up turning too well as we only had one or two students who could actually drive the thing and it still fish-tailed or spun out on occasion during matches (we were also geared for 13 fps which didn't help matters). Since then we've gone back to the long configuration with omnis every year since because it gives us good turning without going overkill like the wide base did with it.
I found a video of ours with some of our practice driving, skip ahead to about 1 minute in to see the robot actually driving around: http://www.youtube.com/watch?v=7ZRYY...nCcI2E3HOLmYKZ I'm sure the blue alliance has some match footage as well but that will probably be far away shots of the field. |
When people say "turn too well" when referring to omnis, what exactly do you mean by that? Do they turn more than the controlled angle? If there were other options to ease in turning, would you suggest omnis over them, or no? If no, then what "them" would you suggest? We are hoping on using 4" wheels for our robot.
Thanks! |
I think the post right above yours answered your question...
Oh. I didn't see the part about spinning our of control. Thanks!
#11
Note when I say "traction wheels," I'm not talking about the kitwheels. i'm talking about aluminum-cut, 2 inch wide IFI roughtop wheels. The definitive stock traction wheel (We used to make some killer custom traction wheels until 2008).
Those things invented wheel scrub. |
#12
Wedge or rough?
#14
#15
Have you guys thought of a six wheel drive wide base? I modified a kitbot at the start of the season to do this (1/8th in drop on the center wheel). I haven't gotten to drive it extensively, but it seems to work.
As for four wheel drive. We have successfully gone two traction wheels in the back (or wherever most of your weight is), and omnis in the front. I can't find a vid anywhere, but those at bunnybot 2010 can attest to the fact that it was quite strong and fast (we were able to tow a goal that was made out of rough plywood on uneven carpet and win a few pushing matches). It was also very easy to drive (we managed to deliver coffee without spilling it ). If you don't want to modify your bot to try it out, you can build spacers that allow you to put two omnis on one hub, allowing you to simulate a full width wheel. Last edited by Garrett.d.w : 02-02-2012 at 00:20. |
