Go to Post "FIRST is like a pizza, we all think different toppings should be on it" - Andrew Schreiber [more]
Unread 01-02-2012, 12:42
dcarswell's Avatar
dcarswell dcarswell is offline
FRC Mentor/Old Dominion University
AKA: DeAndre Carswell
FRC #3359 (Royal Robotics)
dcarswell is an unknown quantity at this point
RUNNING CODE WITHOUT BUILDING
Is there a way to run the code in Labview from the Block Diagram screen, without building and compiling the entire project every time. Should the driver station be open ? I clicked the white arrow at the top, but nothing is giving.
Unread 01-02-2012, 12:51
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
Team Role: Coach
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Re: RUNNING CODE WITHOUT BUILDING
If the vi is part of the realtime target, you should be able to hit the run button without building and deploying. This runs the program and you can interact with any panels. If you reboot the crio, the program is gone.
I keep the driver station open just to verify I have communication and the program is in fact running, but it is not req'd unless you are doing things within telop or autonomous, then you need the driver station to set those modes and enable the robot.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 01-02-2012, 12:54
dcarswell's Avatar
Okay, thank you.
Unread 01-02-2012, 12:55
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
You will need to use the White Arrow only from the Robot Main.vi, rather than from the individual vi's such as Teleop.
Robot Main calls everything else, so Begin gets called to open devices and Teleop gets called when the Driver Station is put into Enabled/Teleop mode.
Trying to use the White Arrow in Teleop, first doesn't have any devices open, and second will only execute a single time, since Teleop is normally called from a loop in Robot Main.
You can open any of the vi windows while the program is running in debug and see what's getting updated in each block diagram and on each front panel.
Unread 01-02-2012, 13:04
dcarswell's Avatar
Okay thanks Mark, that's what the problem was. We were trying to run the teleop.vi, instead of the robotmain.vi. This solution fixed our problem. It is greatly appreciated.
Unread 02-02-2012, 00:17
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
Rookie Year: 2010
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Just a tip: each front panel open requires cpu and bandwidth to update from the cRIO. The more front panels, the more resources simply updating the screen consumes. If this becomes a problem, simply save and close your subVIs.
Mike B
