Go to Post Can anyone tell that it is 5:20 in the morning and I can't sleep? Thanks, Dave. - ChuckDickerson [more]
Unread 02-01-2012, 04:12 PM
WilliamY WilliamY is offline
FRC #0342
WilliamY is an unknown quantity at this point
Question FRC Plugins Won't Install (Netbeans on Fedora)
Now, this isn't an immediate issue, seeing as how I've just been using Windows, but it's still bugging me. When the install.xml runs, I get this error (has been seen over several plugin versions).
Code:
/home/team342/sunspotfrcsdk/install.xml:183: The following error occurred while executing this line:
/home/team342/sunspotfrcsdk/lib/WPILibJ/build.xml:43: The following error occurred while executing this line:
/home/team342/sunspotfrcsdk/ant/preverify.xml:54: Execute failed:
java.io.IOException: Cannot run program "/home/team342/sunspotfrcsdk/bin/preverify" (in directory "/home/team342/sunspotfrcsdk/lib/WPILibJ"): java.io.IOException: error=2, No such file or directory
Those lines it references are
Code:
<ant dir="${wpilibjhome}" antfile="build.xml" inheritall="false" target="create-lib"/>
Code:
<antcall target="jar-app"/>
and
Code:
<exec executable="${preverify.executable}" failonerror="true">
in that order.
This appears to be nowhere here or on Google (at least as far as I have seen), leading me to believe this is an issue with my machine. I have tried this on various versions of both Netbeans and Java. I checked alternatives to make sure Java was assigned correctly. Anybody have a clue?
