Go to Post From a coaching standpoint, I can tell you...the coach is NOTHING without valuable scout information. If the coach is nothing, the robot is NOTHING. It all starts from the scouts...get your kids to see this. - Brandon Holley [more]
Unread 01-02-2012, 18:18
jaysun jaysun is offline
Rookie Year: 2000
jaysun is an unknown quantity at this point
Rectangle Recognition
Hello,
How are you guys recognizing the retroreflective rectangle with the LabVIEW example?
For our team, the code keeps looping between recognizing the rectangle for less than a second and then deciding it's not a rectangle before recognizing it again. We only achieve these results by shining a bright LED flashlight from near the camera lens toward the rectangle.
Will a ring of LEDs work, or is there anything else you guys are using that might work?
Thanks.
Unread 01-02-2012, 22:06
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
Rookie Year: 2012
dvanvoorst is an unknown quantity at this point
Re: Rectangle Recognition
A ring of LED lights around the camera works great! If you use a particular color, such as red LEDs, then you can filter your image for red objects.
Unread 02-02-2012, 15:19
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
Rookie Year: 2012
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
A light ring is a great way to do it, though consider when you choose your color what colors are likely to be in the environment
If you are just using the stock example, take a look at the NI Vision Assistant, it's a handy tool for tuning the vision detection algorithm for your situation. You'll want to play around and find what works best for your lighting situation.
Theres alot of great information in the NI Vision white paper for how to setup the vision assistant as well, and be sure to tune the settings on your camera (like the brightness) to get the best results.
Unread 02-02-2012, 15:35
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Don't use red!
The lights are red and blue, depending on the alliance...
Unread 02-02-2012, 16:43
But the red and blue alliance lights are relatively small. They are not 18" x 24" hollow rectangles. So, it shouldn't be difficult to use red or blue even in the presence of an alliance light, with your ring-light reflecting off of the diamond plate, and with a team with red and blue T-Shirts at the driving stations.
Greg McKaskle
Unread 02-02-2012, 17:43
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
But why not just use a color that is not one of the alliance colors, say green LED lights...
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 02-02-2012, 18:50
Thinking about what is on the field and will show up in the image is a very good idea. If you can guarantee a unique color, it will allow for simpler processing. If you cannot guarantee it, and it breaks the simple targeting, and the options are to modify the color, or up the processing to use additional features.
Greg Mckaskle
Unread 02-02-2012, 18:51
ganchara ganchara is offline
FRC #2523 (Hilltoppers)
ganchara is an unknown quantity at this point
well, the site my team was planning on getting our ring led's from is sold out of 60mm diameter green ring LED's
Unread 02-02-2012, 20:52
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
Team Role: Mechanical
Rookie Year: 2010
KennyLives is an unknown quantity at this point
We use LED rings (Angel Eyes) from www.superbrightleds.com . They are perfect for this job.
No leaks. Ever.
