Go to Post Want the TL;DR of it? Keep it simple, effective, and easy to use. - Andrew Schreiber [more]
  #16   Spotlight this post!
Unread 02-02-2012, 20:06
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
Rookie Year: 2007
chmconkling is an unknown quantity at this point
Re: pic: Gasp!
Originally Posted by akoscielski3 View Post
I'm debating whether your "gasping" about the jaguar used for the motor, or that zip ties are connecting them to the electrical board? Is zip ties legal to use as the connectors for the controller??
we have been using zip ties on ours for years theres a chance of shortage with screws
  #17   Spotlight this post!
Unread 02-02-2012, 23:43
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: pic: Gasp!
Originally Posted by gpetilli View Post
We are doing the same thing. The 393 data sheet calls it a 7.2V motor with 8.5V max so you are correct to be worried about applying 12V. Assuming you use CAN bus, the Jaguar allows you to set a VMax for lower voltage motors. I dont think i would try this using only PWM input to the Jaguar.
No matter what you set the VMax to, the motor will still see full voltage (between 13 and 7 volts depending on state of charge and current draw). VMax pulses the motor to limit the AVERAGE voltage. The maximum voltage actually supplied doesn't change.
  #18   Spotlight this post!
Unread 03-02-2012, 00:02
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
Rookie Year: 2011
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: pic: Gasp!
We actually tried running vex motors off a 12v supply during OCCRA, blew them out faster then you can believe.
Also, Par_Wig is correct, even setting VMax to 7v killed the motors
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
  #19   Spotlight this post!
Unread 03-02-2012, 04:54
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Team Role: Coach
Rookie Year: 2007
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Re: pic: Gasp!
A little clarification on the picture...
The main point of the picture is that we(the electrical team) thought it would be somewhat humorous to control a Vex motor with a jaguar.
We don't plan on doing anything of this sort, especially after the insight given in this thread. This was merely a little test to see how it would behave.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
  #20   Spotlight this post!
Unread 03-02-2012, 08:13
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: pic: Gasp!
Our breadboard uses two VEX motors, one with the KOP VEX controller tied to a standard PWM output and one tied to a CANJaguar with VMax set to 7V and a 10T Potentiometer for position feedback using the PID (P=250, I=0, D=0) in the Jaguar. Both are working flawlessly. We have not put a scope on the Jaguar output, but we have blown any motors. Your photo is not as crazy as you might think, other than you show using a PWM cable to the Jaguar which may be risky if you command more than +/- 50% percentVolts. Size and weight of the VEX is very attractive for controlling a turret which has a high COG.
