Go to Post You are becoming the leaders of tomorrow by leading today. - Chris Fultz [more]
Unread 01-02-2012, 23:32
Programs-R-us Programs-R-us is offline
FRC #3313
Programs-R-us is an unknown quantity at this point
Working with Ultrasonic Range Finder (And other Labview Issues)
So, I'm taking care of trying to add an ultrasonic range finder, to calculate the distance from the hoop to the bot. The problems I'm having are these; One, using an analog input, How do I conver the pulse and voltage info to distance, and two, Where should the range finder be mounted for the optimal distance?
Thank you for any help offered!
Unread 02-02-2012, 07:55
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Re: Working with Ultrasonic Range Finder (And other Labview Issues)
There is an example of how to use the ultrasonic sensor that is installed with LabVIEW. The project can be found on your computer at the following location: (LabviewInstallFolder)\examples\FRC\Analog\EZ1 MB1010 Sonar Analog
An ounce of perception is worth a pound of obscure.
Unread 02-02-2012, 12:40
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Or from the front screen of LabVIEW, select Support then FRC example finder. From there choose sensors and then EZ1 MB1010 Sonar - Analog.
