Go to Post yes, we've gone over every possible idea multiple times. No, we're not going to stop. Welcome to FIRST. - logicalyrandom [more]
Unread 02-02-2012, 00:44
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Grease for CIM-Sim
This year we are using CIM-Sims, and when we tested them today the grease we have spun right of the gears because of the speed. What would other teams suggest for lubrication for these gearboxes.
Thanks
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 02-02-2012, 00:48
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Grease for CIM-Sim
I'm pretty sure the grease that we use on all of our gearboxes is McMaster Number 1392K31. It seems to work just fine for us, but then again, we have never used the CIM-Sims.
I'm right 90% of the time, so why worry about the other 3%?
Unread 02-02-2012, 01:14
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
One of my favorite gear greasing tricks is to open up one of the older FP gearboxes and get some grease out (back in the day, they put quite a lot in). I don't know what type it is, though, but it's not exactly thin.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 02-02-2012, 01:42
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
I'd use white lithium or plain lithium. cheap and effective.
but I have used tho following in the past for gearboxes (all donated):
-"food grade" white butter colored grease
-Ford/mercury black grease (wear junky shirts when using! it stains!).
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 02-02-2012, 02:17
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Probably molybdenum disulfide grease.
Unread 02-02-2012, 07:46
ratdude747's Avatar
AKA: Larry Bolan
I was guessing that it was "moly grease". However, it has been 6 months since I have been to their shop and I forgot exactly what it was. All I know is they were given a couple large grease gun tubes of it and that for AM gearboxes, it works well.
Unread 02-02-2012, 08:25
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
Rookie Year: 2000
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Don't worry about the grease "flying off". All you need is a light film to protect the gears. If you put too much in it will begin to churn around the gears like a pump. Although it may look like there is no grease on the gears there is in fact a light coating. Too much will zap huge amounts of power and generate a great deal of heat, eventually causing the grease to melt and leak out onto something that doesn't like it nearly as much as the gearbox... likely a C-Rio or some electronic doo-dad according to murphy's law.
The grease inside the fisherprice gearboxes is garbage- I would bet it's made from congeiled McDonalds fryer waste. The FP boxes are not made to last and as such they put the cheapest lube in them they can find. It will not tolerate high heat, is not meant for metal gears and is prone to drying up into the consistency of something resembling ear wax. Your best bet for greasing gearboxes like those would be a good synthetic spray lube like HHS2000 made by Wurth. It sprays on from an aerosol, dries to an excellent consistency for small gears, withstands high heat very well and is easy as pie to spray through a little hole if you wish to reapply. It's actually quite a phenomenal product- it has a unique "stickyness" almost like an adhesive where it sticks to anything and everything making it great for high speed applications but terrible to get off your hands - especially because it's water repellant.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 02-02-2012, 02:06
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
They are still packed with a boat load of grease. In fact, that is exactly what I was going to recommend.
We made a single stage gear box this year using a gear from the FP trans. So, we just left it good and greasy! I think tomorrow I will swab a little of that same grease on the CIM-Sim as well. The only thing to consider is how to keep it from flying off.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 02-02-2012, 02:20
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Manually spin the gears by hand (or attach a cordless drill to the gearbox output) at low RPM after they are greased and before you give them full power. This will help the grease initially spread out throughout the gears without flying out due to the high RPM.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 02-02-2012, 04:22
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
I agree with Art, its very easy if you spin the shaft slower and let it settle/spread.
We had issues with that as well, we have started using a dry grease which we really like.
DuPont (Dry-Grease) - McMaster (#8710T35)
-Sourced: http://wcproducts.net/how-to-gears/
We've really liked the above grease, you spray it on, let it dry. Do a coat or two and its good to go. It doesn't fly off and it doesn't get your frame/robot dirty.
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
