Go to Post All the same lessons that can be learned or taught with custom drive trains can also be learned or taught with custom manipulators and scoring mechanisms, and the latter is far more likely to set your team apart in the competition. - Jared Russell [more]
Unread 02-02-2012, 08:13
maria_edu maria_edu is offline
FRC #1811
maria_edu is an unknown quantity at this point
Angry CRIO Issues
When i re-image the CRIO, im not getting any connection, but i do get the light from the CRIO. My question is how do i troubleshoot the CRIO? The electronics are fine and it has previously worked before. Any suggestions are welcomed. Please and thank you.
Unread 02-02-2012, 08:37
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: CRIO Issues
A little more detail would help. Does the FRC 2012 cRIO Imaging Tool successfully format the cRIO, or does it give an error message? What connection are you not getting? What light from the cRIO are you talking about?
