Go to Post Teams need to make 'don't be a jerk' a part of their culture, and that culture needs to be explained to the parents who travel with you - Libby K [more]
Unread 02-02-2012, 14:02
loafdog loafdog is offline
AKA: Maciej
FRC #2876 (DevilBotz)
loafdog is an unknown quantity at this point
Getting BinaryImage write to work
Hi,
My team has tried using BinaryImage write() but could not get any files to appear in root dir on crio. I was playing with it a bit last night and eventually got images to appear. I have a few questions.
Given something like:
BinaryImage img = image.thresholdRGB(0, 40, 25, 255, 0, 40);
1- img.write("thresh.jpg"); did not work. img.write("/tmp/thresh.jpg"); did not work. img.write("/tmp/thresh.png") works. I did not try other file types. Not sure if writing a .png to / works or not... it was late and I was happy to get something working. Any ideas why using jpg does not work? Any reason writing to / may not work? I don't remember if I tried writing png to /. I am able to ftp the camera test sample jpg images to /. I did not try creating/writing to a text file yet.
2- the png image was either all black or had some red pixels/particles. We are using a green ring light. Our camera, RGB values, and filters need tuning but we should get something other than black/red. I looked in sunspotfrcsdk/lib/WPILibJ/src/edu/wpi/first/wpilibj/image/BinaryImage.java and found:
Code:
   public void write(String fileName) throws NIVisionException{
        Pointer colorTable = new Pointer(1024);
        //Black Background
        colorTable.setByte(0, (byte)0);   //B
        colorTable.setByte(1, (byte)0);   //G
        colorTable.setByte(2, (byte)0);   //R
        colorTable.setByte(3, (byte)0);     //Alpha
        //Red Particles:
        colorTable.setByte(4, (byte)0);     //B
        colorTable.setByte(5, (byte)0);     //G
        colorTable.setByte(6, (byte)255);   //R
        colorTable.setByte(7, (byte)0);     //Alpha
        try {
            NIVision.writeFile(image, fileName, colorTable);
        } finally {
            colorTable.free();
I changed two lines to:
Code:
        colorTable.setByte(5, (byte)255);     //G
        colorTable.setByte(6, (byte)0);   //R
After that saved images contained green pixels. I could see what thresholdRGB and convexHull and other filters were doing. Is this the right thing to do to get green images to appear? Seems like a hacky kind of way to make it work, but I'll take it for now.
-Maciej
Unread 02-02-2012, 14:08
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Getting BinaryImage write to work
A binary image, has by definition two possible states for each pixel. What color you make the two states appear as really doesn't matter. If you want them to be black and green because you have a green ring light, go for it. If you want them to orange and purple because those are you favorite colors, you can make it do that instead.
Your method seems to be the correct way of having the "true" pixels output as green to me.
Unread 04-02-2012, 12:14
mryfrmr's Avatar
mryfrmr mryfrmr is offline
AKA: Mary Farmer
FRC #0191 (XCATS)
mryfrmr is an unknown quantity at this point
We have found this morning that the write method on the binaryImage does not work with .jpg format, everything comes out black. We changed the format to .png and everything looked as we expected. So use .png format.
Unread 04-02-2012, 18:33
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Or .bmp or .tiff
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
