Question for anyone who has been or is a Key Volunteer @ an Event
Does anyone know what brand of radio FIRST uses for the volunteers to communicate with one another? I would like to buy my own pair of headsets that are compatible with them that won't leave my ears bleeding by the end of the weekend.
Re: Question for anyone who has been or is a Key Volunteer @ an Event
They've been 2-pin headset connectors on Motorola radios. No idea what the arrangement is with the supplier, so this is definitely subject to change.
The main problem I have with the FIRST supplied headset is that metal piece that wraps around the ear. My ears are burning terribly by days end. Someone mentioned a customized earpiece they got for themselves and since I'm doing 8 events and will be lead que at four of them (three haven't contacted me yet) I think it's in my best interest to get something comfortable.
Frank Larkin is buying radios and headsets for the MAR events - he can probably give you some leads for sources, as he is very diligent in his research. Michigan also bought their own radios and headsets as well.
This is the one I use. Has worked well for me, especially the soft earpiece.
http://www.discounttwo-wayradio.com/BDN7203A |
The two pin Motorola is here for a while. Last edited by RoboMom : 03-02-2012 at 16:12. |
I should look into seeing if I can write off the expense on my taxes. |
#10
My headset arrived but I think I'm gonna have to special order the right kind of plug in for the radio. The one I got is single and Motorolas have dual plug ins.
#11
For anyone else wondering, the connector you need for the Motorola radios used at FIRST events is the 2 pin M1.
#13
Don't you mean Ready to Rumble? Rock and Roll is so 2007...
#14
That too.
