ok we are rookie team and im having problems with the motor controls im using labview but when i leave everything on defualt when i followed tutorial i ran the file and it said everything was working but i get a yellow flashing light in the black jaguar and when i use the joysticks nothing happens to the motors any help vets or anyone who knows what to do???
Re: Flashing Yellow Jaguar
Check your connections. The yellow flashing light on the Jaguar means no signal.
Some other things to check: --DB37 cable from the second module to the Digital Sidecar --PWM orientation from Sidecar to Jaguar (had that with a team last week) --Robot code loaded --Robot enabled in teleoperated What is the RSL LED on the Sidecar doing? |
Some of the ribbon cables in the kit were not assembled correctly:
--PWM orientation from Sidecar to Jaguar (had that with a team last week) --Robot code loaded i need help loading the robot code i enable in teleoperated and it for the main drive any clue what to do? |
Learn to speak English
Then you may want to check your ribbons, as there were some defective ones sent out. |
