Go to Post I predict someone has to eat a hat! :D - FiMFanatic [more]
Unread 02-02-2012, 17:34
commonsense commonsense is offline
FRC #3452
commonsense will become famous soon enoughcommonsense will become famous soon enough
Projectile Motion
Hey does anyone have a good algorithm for finding the velocity needed for the ball to go a certain distance and height. We have been working on it, but it has been pretty drab, and one of our programmers walked out on us because of it (of course he was pretty tired and needed food.) Or if you already have it programmed in LABview that's what we are using. This would be amazing cause it has been really nerve racking to try and do the physics (it's been months since I have had to do this work.) Thanks
Unread 02-02-2012, 17:40
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Projectile Motion
Doing the math can certainly help (and is very educational)... but personally, I would rather set it up with trial and error. Get your robot set up so you can easily change the shooter speed (using a potentiometer on the OI, for example), and feed in balls until you find the right speed for a given distance. Do this for several different distances, plot the results, and find a line of best fit (linear, quadratic, whatever gives the best results).
Unread 02-02-2012, 23:41
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Or discretize your parameters and use a lookup table (optionally add interpolation to this to get a piecewise model).
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Last edited by RyanCahoon : 03-02-2012 at 01:12. Reason: only the parameters need to be discretized. the values stored in the table can be of arbitrary precision
Unread 03-02-2012, 07:26
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Yeah trying to figure it out yourself is probably way too hard. I don't think you necessarily have to come up with a model by trial and error though (even though that might be conceptually the simplest solution). You could probably find many models online that are very accurate (i.e. they incorporate drag, backspin and frontspin, and other factors). I think there might even be some that were created specifically for FRC, and are modeled off the balls we are using. With the material and weight of these balls, a simple parabolic motion model is definitely not going to be accurate.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
