Go to Post If you use a flux capacitor make certain it is a COTS component, or that you fabricate it from COTS materials. - Richard Wallace [more]
Unread 02-02-2012, 18:26
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Rookie Year: 2011
Biolore is infamous around these partsBiolore is infamous around these parts
Using Command base system
so... I'm trying to use the new command base system, so I've gone through the cookbook thing. I don't understand how to make a button on a controller link to a command. The cookbook uses a button class that isn't in the library, so how does this work?
